Sway Bar Database
Old Aug 17, 2006 | 07:48 AM
  #41
Armitage's Avatar
Armitage
Question. I know on my FWD Honda Prelude most people said it was really only necessary to install a rear sway to help with handling, mostly to make the rear-end rotate. Is that the case with the Z as well? Is it worth it to upgrade both the front and back?
Old Aug 17, 2006 | 07:50 AM
  #42
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
totally different platforms - the Z really handles best with both front and rear. Both together help reduce body roll substantially, front helps turn in, rear helps over "bite"
Old Aug 17, 2006 | 10:13 PM
  #43
Gsedan35's Avatar
Gsedan35
^+1
Old Aug 18, 2006 | 06:46 AM
  #44
Armitage's Avatar
Armitage
Thats what I figured. Thanks for the response.
Old Aug 25, 2006 | 06:20 PM
  #45
jinsei888's Avatar
jinsei888
The Cusco sway bars clear the HKS Ti TD very well:
https://my350z.com/forum/showthread....=1#post2717512
Old Aug 25, 2006 | 06:41 PM
  #46
dave3529's Avatar
dave3529
does anyone have any experience with tanabe sway bars, i was thinking of getting them because i have there springs but i have not seen any reviews about them.
Old Sep 10, 2006 | 11:23 PM
  #47
Armitage's Avatar
Armitage
So what are the pro's/con's of running hollow vs. solid? It seems like hollow does not give up noticable amount of stiffness versus the sold, but would help keep extra weight down.
Old Sep 11, 2006 | 04:00 AM
  #48
Z1 Performance
Former Sponsor
do some searches - its been discussed many times
Old Nov 29, 2006 | 10:04 AM
  #49
z-u-later's Avatar
z-u-later
Originally Posted by GTNPU Z
I ran into a question today about sways & I think we should include information on what exhaust systems fit & cannot fit with particular sways.
I'll be the first...
Hotchkis: Fits with Fujitsubo Legalis-R, Borla TD, Nismo, HKS Hi-Power Duals, Injen
Thanks!
Just installed my Injen Super SES dual exhaust system last night and it fits with the Progress Tech rear sway bar & GT Spec rear lower lateral bar.
Old Nov 29, 2006 | 12:18 PM
  #50
BlackZero6's Avatar
BlackZero6
i have tanabe sways...love em....comparable to nismo
Old Dec 7, 2006 | 07:12 AM
  #51
Cloud's Avatar
Cloud
stiffness: 9-32-63 / 54-92-146%; both 5-way [4]
So when it says 146% stiffer for the hotchkis does it mean is the multiplier 1.46 or 2.46(246%)?
i.e when the stiffness is lets say, 10, using the hotchkis rear at the stiffest will be 10 x 1.46 or 10 x 2.46?
Old Feb 1, 2007 | 01:33 PM
  #52
ZtrackFL's Avatar
ZtrackFL
Default Nismo Sway Bar, question
Can I use the Nismo Sway Bar on a 06 Track Model with VDC? If not what other brands can I use.
Thanks
Old Feb 1, 2007 | 01:47 PM
  #53
Z1 Performance
Former Sponsor
yes absolutely can
Old Feb 20, 2007 | 01:04 PM
  #54
icedoutis's Avatar
icedoutis
any issues with either Cusco or Hotchkis and the aps 2.5" or 3" exhaust?
Old Mar 4, 2007 | 03:24 PM
  #55
azula's Avatar
azula
^ good question +1
Old Mar 11, 2007 | 05:55 PM
  #56
ripdrift's Avatar
ripdrift
I have the h&r front and rear sways and have been running them for about 3 months. They are solid i think cause they are way heavy, more than stock at least. The differance is night and day though. I have stock suspension and there is very little body roll in the front on the lightest setting and in the rear on the hardest setting there it is obsolete. how ever my car is stripped so it might be different with some weight. The bushings the come with are kick *** too. I havent even greassed them yet and still no noise.
Old Mar 23, 2007 | 02:10 AM
  #57
jreiter's Avatar
jreiter
I know this is an old post, but I figured I'd chime in just so it's noted in here. If an aftermarket swaybar is listed as 146% stiffer than stock, then you take the stock strength and multiply by 2.46 to get the aftermarket strength. A bar that is 100% stiffer is double the stiffness, so you'd multiple by 2.
Old Mar 29, 2007 | 03:02 PM
  #58
daveh's Avatar
daveh
http://www.whiteline.com.au/docs/bul...%20Swaybar.pdf
Here's an interesting read.
It confirms my findings of the hollow bars not having anywhere near the stiffness of the solid bars.
Old Mar 29, 2007 | 03:05 PM
  #59
Z1 Performance
Former Sponsor
not for nothing but what you expect a manufacturer who sells solid bars to say?
the ONLY way to know what is stiffer, or not, is to measure it...and that takes some expensive machinary. Anything short of that is purely a guess
While my preference is solid bars as well for my own cars, I could not say which bars have the stiffest overall rates as it's beyond what I can measure here
Old Mar 29, 2007 | 03:21 PM
  #60
daveh's Avatar
daveh
Point taken. I'm not saying that one is better over the other. In fact, I'm in the camp that softer setups work better on our cars. I've found the stiff setting on my solid bars to be too much for my taste. Having owned both hollow and solid bars, their data seems accurate to me. There are of course other variables such as bushing material on my two setups that would also cause differences in reaction.
