installed camber arms car sits higher
Old Jul 23, 2005 | 05:17 AM
konspec's Avatar
konspec
Default installed camber arms car sits higher
Just installed my SPC camber arms and bolt. Alignment is horrible so i'm taking it today to get hooked up. The rear of my car sits about 1/2 in higher then it did.
why?
Old Jul 23, 2005 | 10:33 AM
JETPILOT's Avatar
JETPILOT
Likely becasue you jacked the car up... you need to drive around on the suspension to settle it again.
Respect
JET
Old Jul 23, 2005 | 11:22 AM
Zivman's Avatar
Zivman
Respect
JET
+1
Old Jul 23, 2005 | 03:30 PM
protocav's Avatar
protocav
typically, when a car has a lot of negative camber it tucks the tops of the wheels, and makes it look lower. you probably fixed the camber a little bit by installing the arms, so it gives the illusion of being higher.
i typically adjust the rear of my car to sit lower before an alignment. after the alignment, it looks level.
Old Jul 24, 2005 | 06:21 PM
konspec's Avatar
konspec
exactly thats what I'll do. it just took me back alittle bit. And yes i found out the springs settle in the basic tuning for dummies class. can't wait to get my alignment right now my car feels like a wet noodle
Old Jul 24, 2005 | 10:59 PM
gps321's Avatar
gps321
Where can I buu the SPC camber arms? Are they good quality?
Old Jul 25, 2005 | 06:04 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Yes they are good quality, along with their toe bolts your rear alignment should be ok even with a 1.5" drop. I have them and Im lowered probobly almost 2" and Im barely out of rear camber spec. www.iapdirect.com
Old Jul 25, 2005 | 08:23 AM
gps321's Avatar
gps321
iapdirect doesn't have them listed for the 350Z.
Old Jul 25, 2005 | 09:24 AM
~~O8>'s Avatar
~~O8>
The camber actually conceals the true ride height drop, the wheel sit like this with camber // \\ so obviously when you correct the camber and it will be in a more upright position [] [] The sidewall that was turned in will now be sitting in a flatter upward position and the bottom or the wheel will be pulled in more, creating a more proper contact patch.
I dunno if this will make sense...
Old Jul 25, 2005 | 09:25 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Look harder, its right HERE
etkms
Jun 19, 2022 06:30 PM
m_0g
Jun 3, 2021 10:05 AM
Juztin
Nov 22, 2015 07:03 AM
Suffolk350z
Sep 13, 2015 02:43 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
