Which Brake pads to use?
Old Aug 21, 2005 | 12:27 PM
Triple8Sol's Avatar
Triple8Sol
Default Which Brake pads to use?
Details: My car is a daily driver. It's cold and wet occasionally here in Seattle. I started autox this year and will continue a couple times a month 'til end of the season. I'm hooked, so same thing next season. I've got a set of crossdrilled/slotted rotors waiting to go on my stock Brembos.
I'm trying to find a good pad to use. Pads I've looked into are a few from Carbotech, Porterfield R4-S, EBC Redstuff & Yellowstuff, Axxis Ultimate & Metal Master. Right now I'm mainly trying to decide between the Hawk HPS and the HP Plus. I know the HP+ will be better on the track, and I'm not concerned about the extra dust.
Will the HP+ be completely safe on the street when it's not completely warmed up?
Will it make too much noise? I can't stand squealing...
Anybody have experience with any of these pads on your daily driver/weekend racer?
Old Aug 22, 2005 | 01:48 PM
KNS Brakes's Avatar
KNS Brakes
Vendor - Former Vendor
The HP+ will squeal - and dust pretty good too. That means you are stopping.
They are still probably the best autox pad out there. Cold bite is very good you shouldn't be able to fade them.
Drilled rotors should be ok for autox but I'd watch them closely if you do a track day - they tend to crack at the holes far before they are worn out.
Good luck keeping up w/ the WRX/STi/EVO's in the rain!
Old Aug 22, 2005 | 03:22 PM
sentry65's Avatar
sentry65
the burninator
i think most people use HPS for street and HP+ for track/autox
Old Aug 23, 2005 | 06:58 PM
Triple8Sol's Avatar
Triple8Sol
For those of you that have used the Axxis Ultimates, how is the noise in daily driving?
Old Aug 23, 2005 | 07:11 PM
Triple8Sol's Avatar
Triple8Sol
Like I said above. I autox a couple times a month too. That's why this decision is more confusing for me.
Old Aug 24, 2005 | 08:05 PM
racin's Avatar
racin
You SHOULD NOT be using Axxis Ultimates for track days. Period. You will wind up surprised sooner or later, and hopefully it won't be a place with nowhere to go. Trust me on this, please.
Oh yes, HP+ will squeal and dust, but they'll be fine when cold on the street. If squeal is a concern of yours, then pass on them. HPS or some other similar pad will work fine for 95% of autocross courses. Don't use HP+ or HPS for track days either...
Old Aug 29, 2005 | 10:58 PM
Triple8Sol's Avatar
Triple8Sol
So are you also saying that the Axxis Ultimates would be ok for AutoX? They're ceramic, so it "sounds" very similar to the Hawk HPS...
Old Aug 30, 2005 | 05:55 AM
racin's Avatar
racin
Yes, they would work for autocross, although depending on what tires you are using, you may want a pad with more initial bite. You'll have to feel for yourself to decide.
Old Sep 21, 2005 | 09:25 PM
Triple8Sol's Avatar
Triple8Sol
Decided to go w/the Axxis Ultimates since they were 2/3 the price of the HPS, and 1/2 the price of the HP+. I'll be installing them this Sat. along w/my Hotchkis sways and GT spec braces, so I guess we'll see...
samansharif
Sep 25, 2015 12:31 PM
