To guys that lowered the Z 1.2+ inches
Old Sep 12, 2005 | 11:28 AM
Hybrid90's Avatar
Hybrid90
Default To guys that lowered the Z 1.2+ inches
For all you guys that lowered your Z 1.2+ inches, can I get some information on this. What setup did you go with, how was the ride, did you guys scrape everywhere and most important of all, did your camber go way off? Also, was it hard to get it aligned to near stock settings? Just doing some research before I lower mine... thanks in advance!
PS any info about lowering is also appeciated.
Old Sep 12, 2005 | 01:54 PM
rocketdog's Avatar
rocketdog
Check out the post "my alignment specs after lowering" a few posts down. Also check a few other of my posts for the last week or so.
Old Sep 13, 2005 | 05:38 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
there are literally tons of threads on this
Old Sep 13, 2005 | 06:31 PM
Enzo Driver's Avatar
Enzo Driver
I just put the Tanabe GF210's on, they are 1/2" Rear, and 1" Front. I went and ripped on some nice roads, and it felt great. It hasnt settled yet, but its gonna look awesome. Ill keep you updated after i get aligned.
Old Sep 13, 2005 | 06:37 PM
rs350z's Avatar
rs350z
I would like to hear some others opinions on lowering the Z. I am nervous to do so. All my other lower cars ultimatley left me with so many headaches
Old Sep 15, 2005 | 08:16 AM
vien's Avatar
vien
From My research on this post, Eibachs will need a camber kit for the rear. Front can be aligned back to specs with the drop. Is this correct?
Old Sep 15, 2005 | 08:18 AM
Z1 Performance
Former Sponsor
there is not front camber adjustment on a Z at all...it ends up where it ends up unless you get adjustable a arms
rear camber with Eibach is a HAIR, and I mean hair off from stock specs...at most .1. or .2 degrees - hardly enough to worry about, and will actually improve handling. If you want to add an adjustable rear kit to it anyway, then you could and you have full alignment control in the rear as well
Old Sep 15, 2005 | 08:23 AM
vien's Avatar
vien
So getting eibach pro kit, my alignment should be within specs?
Old Sep 16, 2005 | 05:04 PM
roncfpz's Avatar
roncfpz
Lowered with TEIN Basic coilovers
Ride was improved
Very little scraping
Camber and toe off
After alignment, rear adjust back to within spec (barely)
Need adj arms for the front
Old Sep 16, 2005 | 10:08 PM
Badmonkey's Avatar
Badmonkey
Eibach Prokit, SPC rear camber kit and toe bolts and a good alignment. All well within specs.
