Tein Basics or something else??
Really interested in the Tein Basics, but want to know if the ride gets harsh? Also, does this setup make the rear bouncy due to the stiffer spring and dampener?
I am also willing to look at other options if anyone cares to share there opinions and info on simpilar setups.
Thanx
Thanx
I have TEIN Basics and the ride is not too harsh or bouncy with stock sway bars. Once I added Cusco sway bars however, it really stiffened the ride. Good coilover for the price.
Good luck!
Ron
Good luck!
Ron
Not too harsh, but definitely stiffer than a typical set of aftermarket progressive springs. (e.g. Eibach Pro-kit)
Definitely no bounce though, it tightens up when the car goes over road-asphalt transitions.
I read somewhere that the Basics are a tad softer than the other Tein Coilovers (e.g. Flex) at their lightest settings?
If your looking for coilovers with a little more comfort, try Tanabe Sustec Pro SOC's with the helper springs. They are considered in the same league as the Basics but priced a little more because of the helper springs. The helper springs are suppose to provide a more comfortable ride while driving in the street.
Originally Posted by Jason@Performance
for the money its a great suspension..
and you have other spring rate options available..
it is basicly like a ride height adjustable NISMO Suspension..
Performance Nissan
Performance Nissan
you can get springs that are of similar spring rates like the RSR...
here is a list of the springs that can be used with the TEIN Basic...
http://performancenissanparts.com/ca...?cPath=292_857
and the rear 350Z / G35 set up has specific springs...
http://performancenissanparts.com/ca...h=292_1319_935
you can go up or down 2 spring rates from what came with the suspension without re-valving... we have re-valving kits available but it is recomended your coil overs are sent to tein... (Just the dampers)
Basic's do not have a 2 Kg range for selecting different spring rates. You only have a 1Kg range as per Tein. The Flex and CS are the setup's can do +or- 2 Kg. Given that some Basic review's have mentioned that they do experience some bounce issues with their Basic's, I would not go higher when considering a rate change. Though Tein would be more then willing to revalve them. doing that will put you in a price range where you really should have made a better product choice to begin with.
