Is it OK to turn slotted , drilled, or drilled-slotted rotors?
Old Dec 15, 2005 | 11:52 PM
ssk0771's Avatar
ssk0771
Default Is it OK to turn slotted , drilled, or drilled-slotted rotors?
I currently have Rotora Slotted Rotors and I am about to get new pads.
I had the rotors turned once.
I am thinking of turning the rotors again but someone told me that you are not suppose to turn slotted rotors.
Is that true?
Old Dec 16, 2005 | 09:13 AM
anotheraznguy's Avatar
anotheraznguy
you can turn slotted rotors. main reason why most shops won't is because there is a good chance of messing up the bit that cuts the rotor down
Old Dec 17, 2005 | 01:45 PM
Triple8Sol's Avatar
Triple8Sol
Whether you have Slotted, Drilled, Slotted/Drilled...it's fine. Like ^^ said, alot of shops won't mess w/it b/c they don't want to take their time doing it.
Old Dec 17, 2005 | 03:46 PM
Yes. If the rotors meet the minimum recommended thickness, machine them.
Old Dec 18, 2005 | 12:09 AM
papag1's Avatar
papag1
also known problems about turning them is that they can get sharp around the edges where the slots/drills are and can eat up your pads very quickly. if you do turn them then sand out the edges to make sure they dont cut the pads...thats what i did atleast
Old Dec 18, 2005 | 06:16 AM
westpak's Avatar
westpak
SFZCC
Also unless you have caused some damage to the rotors they probably do not need to be turned. I have had mine on for a long time and have not turned them.
What makes you think you need them turned?
If it is becuase you are feeling some vibration I would first try a new set of pads and bed them in properly to take off any built up pad material which is usually the cause of vibration.
sherm
Apr 11, 2020 05:21 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
