ZISME: Can Brembo Brakes be installed on Touring Model?
Old Jul 1, 2002 | 08:14 PM
mattc's Avatar
mattc
Default ZISME: Can Brembo Brakes be installed on Touring Model?
Originally posted by DaChoZn1
Does anyone know if there is any possibililty of getting the Ray's wheels and Brembo brakes on a touring package? I order the touring package but, I really like the light weight Ray's and Brembo brakes. To me, that would be the ultimate package.
This has been posted before, but I was wondering if you could provide some insight:
Would it be possible to add the Brembo brake system to a stock Touring model 350Z at some point as an aftermarket add-on? If not, what are the limiting factors (wheel offset, spoke clearance, etc)?
Thanks.
-MattC
350Z Touring, 6MT, Chrome Silver
Plate: ZISBAK
Old Jul 1, 2002 | 08:19 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
just a guess, but among those factors might also be: mounting location (holes) on the suspension for the brakes.
Old Jul 1, 2002 | 09:44 PM
Sanderman's Avatar
Sanderman
Default Answer should be yes
I upgraded barkes on my last 300TT and the only thing to consider was wheel size / offset to clear the larger calipers. Its also a great time to replace rubber brake lines with stainless steel for a firmer pedal feel.
We'll have to see what kind of clearance the Touring wheels spokes provide to see if they clear the bigger calipers, otherwise you'll have to buy new wheels. Mounting points should be a non issue.
joe
Old Jul 6, 2002 | 07:35 AM
raceboy's Avatar
raceboy
You might want to also see if the master cylinder is the same as well.
Old Jul 7, 2002 | 11:19 PM
TXSTYLE's Avatar
TXSTYLE
Default Re: ZISME: Can Brembo Brakes be installed on Touring Model?
Thanks.
-MattC
Plate: ZISBAK
Should be a direct "plug & play".
Old Jul 11, 2002 | 11:17 PM
morganjd's Avatar
morganjd
For some reason I thought if you get the 6-speed on the touring, then your wheels increased to 18's and performance tires, which I assumed to be the same already on the track model. Am I way off?
I know you don't get the Brembo's but I thought the 18's were the Rays.
Dsowe
Feb 17, 2021 10:38 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
