Spring Set-Up Roll Call
I am just wondering what springs everyone is running and how you like them. Hopefully this will help me chose what springs I would like to purchase. Also please note if you have any unusual tire wear or other suspension problems after the spring install.
Springs:
Drop:
Rim size:
Any other suspension mods:
Cost of install or diy?:
Springs:
Drop:
Rim size:
Tanabe GF210:
great spring for the street. Ride is smooth, I've been using them with stock shocks now for over 25,000 miles and everything's still working ok. I'm ditching them for some tokico springs, but just because I want linear springs to race on. The tanabes work just fine for the street.
1.2" rear drop, 1.0" front drop
17x9 +27 with 275/40/R17, no rubbing
-Eibach Pro-Set
-1" Front, 1" rear
-18 x 8.5, 18 x 9.5 (Nismo LMGT-4's)
-Tokico D-spec shocks, Stillen Front A-Arms, Stillen Rear Camber Arms, JIC Magic Rear Toe Arms, Stillen Sway Bars, GT Spec Braces, Prothane Bushings.
-$$$$$$ lost count a long time ago $$$$$$
-1" Front, 1" rear
Tanabe Sustec Pro-SOC Type I coilovers. 1.25" drop. On about 5k miles. NO PROBLEMS. I really like this setup. Thanks to Jason @ performancenissan for the recommendation. Forgot to add, GT-Spec front and rear frame braces, Stillen sway bars w/ Prothane bushings. Wheels are 18" Enkei RPO3, 9"f/10"r, w/ Kumho 245/275 40's. Sorry for the omitted info. I really like my setup.
Originally Posted by Ghost_shift
- Springs: Tanabe GF210
- Drop: 1"F 1.2"R
- Rim size: 19" 245/35F 275/35R
- Any other suspension mods: SPC front A-arm and rear lower controll arms
- Cost of install or diy?: DIY
Originally Posted by USN HM 350Z
-Eibach Pro-Set
-1" Front, 1" rear
-1" Front, 1" rear
I went with the Hotchkis TVS kit and love it. Springs are a conservitive drop as well.
Springs:
Front 9/16" (15mm) Drop
340 lbs/in
Stock 310lbs/in
Rear 3/4" (19mm) Drop
330 lbs/in
Stock 350 lbs/in
Sways:
Specs:
Front: 1 3/8" (35MM) Tubular(Bar Weight 13.5lbs)
4 Position Adjustable
Rear: 15/16"(24mm) Tubular(bar weight 5.5lbs)
3 Position Adjustable
Bar Rates:
Front:
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock) My Setting
Rear:
Hole 1 = 520 lbs/in (80% Stiffer than stock) My Setting
Hole 2 = 655 lbs/in (125% Stiffer than stock)
Hole 3 = 840 lbs/in (185% Stiffer than stock)
$399 from intense.
$150 installed Stock 18" touring wheels w/ BFG KDW tires.
Springs:
340 lbs/in
Stock 310lbs/in
330 lbs/in
Stock 350 lbs/in
Sways:
Specs:
Bar Rates:
Front:
Rear:
$399 from intense.
Springs: Hotchkis
Drop: 1/2" front, 3/4" rear
Rim size: 245/40-18 F, 275/40-18 R
Any other suspension mods: No
Cost of install: $100+
Great ride quality, barely different than stock. Much less body lean up front. Overall highly recommended.
I'm about to try Sprint springs because I want more of a drop. Supposedly they're 1.75" but people are claiming that's overly optimistic. We'll see.
