NEW Stance SUS Coilover Review
hmm, these or buddy club? how stiff are these, to me the spring rates don't make any sence, with such a huge gap. i know its mostly about the valving and the dampening, but are these really stiff? can you get a OEM feel on the softest setting?
Originally Posted by sen_jen
12/5. true coilover. it rides great on the roads i frequent. there are off roading like areas which i avoid. hawaii roads suck fatt a.ss.
..... yeah i know the roads there suck donkey
, ... so it's not a bad ride (all things considering) down Ala Moana, or Nimitz, Kapiolani? Have you ventured up through Tantalus with them on??
just trying to compare them to the HKS LS+'s..... thanks
My right rear side is silent, but my left rear makes a clunk noise under light bumps. I've took it out and re-tightened everything. I have a bit of preload on the spring as well. I also put Dynamat on the uppermounts between the body of the car and uppermount. That seemed to help a bit but the noise is still there. Any ideas?
Well, I rechecked everything & it seems nice and tight. The funny thing is that the squeaking seemed to have gone away now. We'll see how it goes though once I do a little more driving.
Tried the Stances last weekend on my car and they were pretty awesome. I must say, the performance and ride quality of these are top notch. The only gripe I had is that my 315 wide tire rubs on the rear
. Nothing a 3mm spacer and some rolled fenders wont fix.
Originally Posted by NoLimit
cool thanks
a friend of mine has the HKS LS+'s, and i really like the comfort it offers. however, at full slam, it gets crappy (not fully height adjustable).
Originally Posted by first350
A little off subject, but what's in the middle of your front grille area? (BTW nice looking ride - the rims looks great...and with 315 wide tires
Thanks! That thing in the middle of my grille is a transponder (lap timing devise) hanging off of my OEM tow hook. Unless of course you are talking about the huge silver thing that takes up my grille area, then that is my JWT intercooler.
lol...at first it looked like you had 2 smaller IC's welded together in the middle - but I thought I'd ask b/c that wouldn't make sense (your car looks too nice to have done something like that). I've also used the tow hook to zip-tie my transponder to...but the transponder I was using was much smaller.
Well, I drove a littlem more today & the squeeking is still there
. I think I'm going to take it completely off to make sure everything is in order. I might look into someones suggestion of putting some sort of rubber spacer to see if it helps. Kinda sounds like the springs making the noise though. Sounds like it maybe rubbing something as it compresses. As I've mentioned, the noise factor is the only thing I really don't like since I love how this rides. Oh well...I'll keep you guys posted...
hey GTNPU Z what side are you having the noise? cause i have the same problems with the squeaking on the rear right side. i duno what to do to make it stop, if you find a way to make it stop tell me man cause this **** is annoying me.
Edit: I just got back from driving from my GF's house & it hardly made a squeak this time. This thing is definitely moody
. Nothing a 3mm spacer and some rolled fenders wont fix.Did you have any isses with the 315 rubbing the fender previously when lowered?
thanks!!
So your rear tires (315) are rubbing the spring on the coilover? How much clearance does your rim have from the spring? Wheel size / offsets?
thanks!!
thanks!!
give me a pm and i'll let you know =)
also...
the reason z guys hear more than the g guys is simple...
w/ z's there isnt much sound deadening where the rear struts are compared to the g's
also...
Originally Posted by aleok
bump for my question.
can you get an OEM feel on the softest setting?
