Just Got Stillen Sways! Suggestions For Settings
Old Feb 24, 2006 | 07:43 AM
Sundeviljay's Avatar
Sundeviljay
Default Just Got Stillen Sways! Suggestions For Settings
Just got the stillen sways...props to Chadd from Riverside Infiniti!!!! Buy from him! Anyways, I was wondering if anyone could give me a quick run-around of the different settings. I drive mostly freeway everyday and already have the Tein Flex. I definately don't need to be any stiffer. Any suggestions welcomed. Thanks
Also, are there any bushings or collars that I can buy to make the sways better?
Old Feb 24, 2006 | 07:55 AM
1nate7's Avatar
1nate7
I thought Stillen sways already had the collars in them? If they didn't come with bushings, I think a lot of people go with Prothane. Anyway, I would start with med/med. With my Hotchkis sways I have tried soft/med, med/med, and hard/med. Soft up front the turn-in still felt a little sloppy and hard front induced all kinds of weird creaks/moans/rattles over uneven surfaces.
Old Feb 24, 2006 | 08:16 AM
Sundeviljay
i haven't opened the box yet but i am pretty sure they come with collars too. but i think that you have to use the OEM bushings. where do i get prothane bushings? any auto store like autozone or kragen...etc.?
Old Feb 25, 2006 | 06:00 AM
zredline's Avatar
zredline
I have the Stillen Sway bars also and would like to install them in the next few weeks.
I have searched the suspension section and unable to locate any definitive info on which aftermarket bushings to use with the Stillen sways. The Stillen sways are 7/8" rear and 1 3/8" front.
I went to the zchickz site for install proceduers and I noticed the front sways are held in by 4 bolts while aftermarket bushings look like they only need two bolts is this OK. Will the OEM bushings work with the Stillen bars?
Will the following parts work with Stillen sways. Thanks.
Energy Suspension:
Front 1 3/8 P/N 9-.5158
Rear 7/8 P/N 9.5168
Old Feb 25, 2006 | 06:45 AM
Gsedan35's Avatar
Gsedan35
Energy Suspension:
Rear 7/8 P/N 9.5168
All aftermarket sway bars reuse the oem bushing frames in the front that I've ever seen, meaning they are secured with 4 bolts per side. In the rear, the Cusco's I used to have used the oem setup, while the rear 350EVO bar I have now came with it's own bushing frames, either way two bolts per side in the rear.
Yes you can use the OEM bushings with the Stillen bars. Prothane also makes dedicated 350Z sway bar bushings that you can also use.
SUSPENSION RESTORATION PARTS COMPANY
(209) 578-5101
Tech questions & orders
1(800)-291-5340 ORDERS ONLY
319-B MOTOR CITY COURT
MODESTO, CALIFORNIA 95356
Prothane brand
Front bushings Part # 14-1115 $21.00
Rear bushings Part# 14-1116 $21.00
California residents please add 7.375% sales tax
Old Feb 25, 2006 | 07:37 AM
jcpeyton's Avatar
jcpeyton
I've had Prothane bushings installed w/ my Stillen sways since the sways were first installed. They have performed very well w/ no problems whatsoever. Got mine from:
Phil's Inc..Aotomotive Warehouse
2204 Ashland Ave.
Evanston, IL 60201
Old Feb 26, 2006 | 05:38 AM
zredline's Avatar
zredline
Thumbs up
Thank you, Gsedan35 and jcpeyton for your quick responses, I guess I will go with the Prothane bushings.
Thanks again.
Old Feb 26, 2006 | 04:25 PM
Mr.Jadkowski's Avatar
Mr.Jadkowski
Got my prothane bushings from phil's as well. Fast shipping. I'd suggest med/med to start, and then go from there. I didn't notice any reduction in ride quality at those settings, but definitely less body roll and better tracking through corners.
Old Feb 26, 2006 | 09:32 PM
Sundeviljay
used the oem bushings...everything went well. no probs at all. i heard that the prothane or any other aftermarket bushings might cause some noises. and you can only use the bushings on the rear. the front bushings cannot be replaced
Old Feb 27, 2006 | 06:14 AM
Mr.Jadkowski
That is entirely false. Haven't heard a peep out of mine yet, and you can replace the front bushings as well as the rear.
Old Feb 27, 2006 | 07:08 AM
Sundeviljay
is the G different or exactly the same?
Old Feb 27, 2006 | 07:35 AM
Mr.Jadkowski
not positive, but I think it's the same.
Old Feb 27, 2006 | 07:46 AM
Sundeviljay
well, either way i went with OEM and i am good. they feel really nice and solid! great mod
Old Feb 27, 2006 | 10:07 AM
tekk's Avatar
tekk
G is the same
Old Feb 27, 2006 | 06:52 PM
jcpeyton's Avatar
jcpeyton
My Prothane bushings have been in about 8k miles. NO squeaks, NO problems. I installed them both front and rear.
Old Mar 5, 2006 | 02:36 PM
zredline's Avatar
zredline
I picked up Prothane bushings today along with a few other items @ Summit racing, I will try and install within the next couple of weeks providing the weather is decent.
