Lowering Rear
Old May 31, 2006 | 03:26 PM
New2350's Avatar
New2350
Question Lowering Rear
Is it ok to just lower the rear end of my car? I am thinking of the .8 drop on the rear and nothing in the front. I am also putting 19"s on soon. I think I will go with eibach. Thanks guys.
Old Jun 1, 2006 | 01:58 AM
Dubai's Avatar
Dubai
I was wondering the excat same thing. I assume it'll mess with the handling of the car if you just lowered the rear (correct me if i'm wrong!)
Old Jun 1, 2006 | 07:46 AM
VO...'s Avatar
VO...
Administrator
other than your spring compression rate differing from front to rear and buying a set of four springs but only using 2, probably nothing abnormal. 0.8 drop isn't bad. I know from experience that a 0.6 drop in the rear can be realigned to factor specs(camber & toe)
Old Jun 1, 2006 | 11:23 AM
MurphysZ's Avatar
MurphysZ
Tein makes a kit that doesn't drop the car much and it will keep the spring rates the same. My driveway has a huge curb and I have a Mastergrade front lip, if I pull in or back out, it scrapes pretty badly. I can still back in without scraping. Tein will be the only option I know of right now.
Old Jun 1, 2006 | 02:49 PM
VO...'s Avatar
VO...
Administrator
Tein s-tech would offer a 0.6 drop in the rear
Old Jun 4, 2006 | 01:27 PM
jovasi's Avatar
jovasi
Eibach drops the rear 1.25 inches. I would put the front springs on as well if I were you. Eibach fronts lower it 3/4 inch.
Old Jun 4, 2006 | 10:27 PM
New2350's Avatar
New2350
.08 should not take the toe and camber out should it????? Any one got a good price on these springs latley? Thanks for all the help and info.
Old Jun 5, 2006 | 08:33 AM
TreeZ's Avatar
TreeZ
i'm assuming you guys want to even out the car by just lowering the rear. if that's the case, maybe you should consider the rear spring seat mod. cut down the rear spring seat and you can get around 0.2" of drop for free. there's a thread on here somewhere that details this.
Old Jun 5, 2006 | 12:43 PM
New2350's Avatar
New2350
^ is this a good idea?
Old Jun 5, 2006 | 12:56 PM
BhashaZ's Avatar
BhashaZ
Here's the link: https://my350z.com/forum/brakes-and-suspension/187959-06-upper-rear-spring-seat-free-lowering-mod.html
As for whether it's a good idea or not, I have no idea...
