brake pads $$$
Old Jun 24, 2006 | 10:54 AM
rory's Avatar
rory
Default brake pads $$$
where do i get them installed pep boys 300$ midas 355$ anywhere cheaper? i am thinking on doing it my self. is there a diy for the rear and how do you bleed the brakes? video mabey?
thanks rory
Old Jun 24, 2006 | 11:05 AM
GMZ's Avatar
GMZ
WHAT?????WTF? Do it yourself. It takes not even an hour! Im sure there is a DIY, do a search for it. Do not pay anything like those prices. Go with Hawk HPS which can be bought at Pep Boys for about $50-60 for the fronts, rears should be a little cheaper.
Old Jun 24, 2006 | 11:40 AM
nm3th's Avatar
nm3th
misread original post
post deleted
Old Jun 24, 2006 | 12:34 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
here they will charge hyou $140 per axle and this is a dealership... that is including turning the rotors down... or replacing them...
Old Jun 24, 2006 | 02:07 PM
nissansource's Avatar
nissansource
go buy pads at pepboys and ill put them in for a 30 pack
Old Jun 24, 2006 | 10:40 PM
-EL's Avatar
-EL
There is a sticky thread in this very section of the forum on how to do it-
https://my350z.com/forum/brakes-and-suspension-diy/58195-how-to-change-brake-pads.html
As for bleeding the brakes, you don't have to do this to change your brake pads, but if you do need to, you can google "how to bleed brakes" and find dozens of tutorials. Same goes for changing your brake pads, if the one on my350z isn't detailed enough for you.
One thing to remember about brake work is that all car and light truck brake systems work almost identically, so after you've done it once, you'll be able to do a brake job on anything you own down the road. I strongly recommend trying it yourself if you have the tools and are mechanically inclined. It's a bit messy, but on a difficulty scale of 1-10 (one being changing your wiper blades and ten being an engine rebuild) I'd rate it a 3.
-E
Old Jun 26, 2006 | 04:45 PM
rory's Avatar
rory
o what the hell i guess ill do it this weekend. are the rear brake the same as the front? they diy is on the front only. is it that much different on the rear.
Old Jun 27, 2006 | 05:14 AM
-EL's Avatar
-EL
I don't really remember off the top of my head if there is any difference, but if there is, it's not much. Just take the thing apart, apply common sense, and reassemble
-E
Old Jun 27, 2006 | 05:43 PM
GReddySetGO's Avatar
GReddySetGO
If you want, I can do them for you at my shop too. I'm in Pasadena.
Old Jun 27, 2006 | 07:28 PM
Gary King's Avatar
Gary King
If you want Hawk HPS we have them in stock both front and rear for Brembo or 2003-2005 Non-Brembo brakes:
http://storesense.megawebservers.com...tail.bok?no=52
Self install is not that bad but, make sure your rotors are in good shape before just putting a new set of pads on. How many miles and what year do you have? 2006 Non-Brembo calipers are different than 2003-2005.
Thanks,
Gary
samansharif
Sep 25, 2015 12:31 PM
