Spring install help
Old Jul 8, 2006 | 03:54 AM
zredline's Avatar
zredline
Default Spring install help
I am installing H&R Sport Springs and Tokico D-Spec shocks since yesterday, I also did the SPC rear camber toe bolt at the same time. After removing the old spring from the rear bucket there is a rubber spacer in the bottom of the bucket should this be removed or stay in? I am asking this because I initially left it in, put in the H&R springs tightened everything up, put on the wheels and removed the jack stands and F***, the gap between the fender and tire was greater than when I started and the wheels looked like
\ /. I made sure everything was aligned when I placed the springs on the rubber spacers.
I ended up removing the rubber spacer and the spring is now resting on the aluminum bucket, I took the car for a spin granted only a couple of miles but there was no noise.
So should the rubber spacer in the bottom of the bucket be removed or stay in? If it should be in what could be causing the excessive wheel gap? Thanks.
Old Jul 12, 2006 | 04:18 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
sounds like the springs are not seated into the rubber and lower spring seat properly...
Old Jul 12, 2006 | 05:03 PM
zredline's Avatar
zredline
Thanks for the response, I ended up taking everything apart, I aligned the bolts and removed the rubber spacer and the spring is now resting on the aluminum bucket so far no noise not sure if this is correct but it seems to work and the tires seem to be more l l. Next I need to get an alignment. Car looks good, glade I got the H&R's, I will get some pictures in a couple of days.
Old Jul 12, 2006 | 05:59 PM
aleok's Avatar
aleok
i left my rubber things in when i installed my springs....
Old Jul 12, 2006 | 07:20 PM
Jason@Performance
Performance Nissan
you really should put that rubber back in... just asking for trouble down the road...
Old Jul 13, 2006 | 04:54 PM
zredline's Avatar
zredline
Ok, will do, thanks for the info I will try and install on Saturday.
Here are a few pictures from today.
Old Jul 14, 2006 | 05:01 PM
zredline's Avatar
zredline
I added the bottom rubber pieces today took about an hour, checked and double checked everything to make sure they were in place. Looks ok I think it looks like it is at stock height about 2 finger gap between rear fender and tire.
Also the car looks like it slightly slants up front to back I hope the rear seats a little better after driving it.
Old Jul 14, 2006 | 09:47 PM
Jason@Performance
Performance Nissan
pic of it as it is now?
is it an 05?
Old Jul 15, 2006 | 12:20 PM
zredline's Avatar
zredline
My car is an 03, here are a few from this morning.
Old Jul 15, 2006 | 01:36 PM
Jason@Performance
Performance Nissan
whats the part number on the springs?
should be 53050 for the coupe....
53051 for the roadster, which would explain the rear being higher (in the case of the H&R Springs that is...)
Old Jul 15, 2006 | 02:34 PM
zredline's Avatar
zredline
I have the 53050.
Old Jul 21, 2006 | 05:44 PM
zredline's Avatar
zredline
Here are a few pictures from this week.
