Coilover Install
Old Jul 21, 2006 | 11:38 PM
three_fitty's Avatar
three_fitty
Default Coilover Install
Gettin ready to install my Stance coilovers. What have you guys used to hold up the ABS Lines???
Old Jul 22, 2006 | 05:30 AM
Gsedan35's Avatar
Gsedan35
Zip tie
Old Jul 22, 2006 | 05:54 AM
twenzel's Avatar
twenzel
yep, Zip Tie works quite well on my Buddy Club coils.
Old Jul 22, 2006 | 06:23 AM
three_fitty
Awsome guys. Thanks. Any other things i need or have to watch out for when installing coilovers???
Old Jul 22, 2006 | 07:59 AM
jinsei888's Avatar
jinsei888
yes, make sure you slam your car
Stance Coilovers
Old Jul 22, 2006 | 08:25 AM
three_fitty
pimp! Installs been cancelled. Opened one of my rears and the damper adjuster is bent. Gotta send it back.
Old Jul 22, 2006 | 09:50 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Stance Coilovers
oh you just got the rear lifted up in that pic huh
Old Jul 22, 2006 | 08:26 PM
hatchboi's Avatar
hatchboi
good luck on ur install, tell me how it goes, tell me if your car squeaks cause i got stance too and mines squeaks on the rear passenger kinda mad about it but imma find some how to stop it. if you knoe tell me how to fix the squeak thx man
Old Jul 22, 2006 | 09:47 PM
three_fitty
It'll take a few weeks, like i said, gotta send one of the fronts back. The damper adjuster was bent. Pisses me off cuz i waited a month for em.
Old Jul 22, 2006 | 10:20 PM
FrickU's Avatar
FrickU
That sucks, But do a write-up after you install and test them. I'm interested in those coilovers...Probably going to end up upgrading to the stances
Old Jul 22, 2006 | 11:09 PM
hatchboi's Avatar
hatchboi
yea im kinda dissappointed in it cause of all tat squeaking, hope it doesnt happen to yours but make sure you update on what happen
Old Jul 24, 2006 | 12:28 PM
anotheraznguy's Avatar
anotheraznguy
guys have you set proper preload as well as lube it up a lil?
also make sure the top nut is tightened as well.
Old Jul 25, 2006 | 08:34 PM
hatchboi's Avatar
hatchboi
where do we lube it? and how do you preload?
Old Jul 26, 2006 | 08:51 PM
sen_jen's Avatar
sen_jen
^ preload is when you raise the collars just below the spring upwards.
Old Jul 29, 2006 | 09:07 AM
three_fitty
How do i know how much to set the preload??? It says to tighten by hand, then use the wrenches to turn 2 full revolutions. Will this have anything to do with the height as well?
Old Aug 6, 2006 | 02:44 PM
three_fitty
Got them installed. Any one know the stock heights for the fronts? For some reason my drivers side sits 1/4" lower than my passenger side.
Old Aug 7, 2006 | 12:36 AM
sen_jen's Avatar
sen_jen
yeah, what jinsei posted......make sure you slam it like crazy! i almost slammed mine: senjen's g35 pics. as far as your height goes, i'd take the coilovers out, and measure them. re-inspect that the top strut nut is tightened, and ensure that the preload is the same for both sides. then re-install and see.
Old Aug 8, 2006 | 09:10 PM
jinsei888's Avatar
jinsei888
yep
Old Aug 8, 2006 | 10:05 PM
350z_this's Avatar
350z_this
how much did it cost you??? for the stance coilovers?
Old Aug 17, 2006 | 05:49 AM
three_fitty
i'm in canada... paid 1400. tougefactory. pics comin up soon.
