Eibach Pro kit Question
Question for those who have these installed, do you have any camber/toe problems? Also how long do your tires last?
I'm debating on installing these on my car because of these probable issues.
Does anyone know if the G35 Pro kit is any different that the 350Z Pro kit?
Thanks in advance.
Thanks in advance.
I've had the Prokit springs for almost three years now. The 1" drop was enough that my rear toe and camber was out of spec. I went with the Kinetix camber rods and SPC eccentric bolts to build in more adjustability and correct both elements. Each Z will have slightly different build qualities, but I think the SPC bolts will allow your alighnment tech to get your car back to spec. IMHO the handling improvements in the Eibachs alone are worth the install.
seagrasser
Oct 11, 2015 03:27 PM
