e-brake?...
Old Aug 3, 2006 | 05:24 PM
BigZ88's Avatar
BigZ88
Default e-brake?...
Ok, maybe im stupid, but i was changing my brake pads today on my 03 track, and i didnt see any ebrake cable running to the caliper...what's goin on here? Maybe i completely missed it.
I tried searching and couldnt find anything on this...sorry if its been covered
Old Aug 3, 2006 | 05:27 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
The hand brake is a set of cable operated drub brakes inside the rear rotors. They are miniature shoes sort of like older motorcycles.
Chris
Old Aug 3, 2006 | 05:32 PM
BigZ88's Avatar
BigZ88
well thats cool...i'm glad i didnt miss anything. But damn if my e-brake doesnt hold for crap...is that typical?
Old Aug 3, 2006 | 05:37 PM
HyperSprite
Mad Scientist
Yeah, mine holds fine......
....on flat ground.
Chris
Old Aug 3, 2006 | 07:07 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
yes, ebrake is a drum brake on th einside of the rotor...
thats one thing alot of people dont replace is their shoes especialy if they do alot of ebrake stuff etc...
there is an ebrake adjustment which is what that little rubber thing is covering in the rear rotor...
Old Aug 3, 2006 | 08:57 PM
MyNismoRoadster's Avatar
MyNismoRoadster
..or you can take the slack out by tightening the cable.
Old Aug 18, 2006 | 03:20 PM
kensin0429's Avatar
kensin0429
weird
my ebrake works find on the flat ground even on a lil inclin
but when i pull the E while stil drivin the weels dont lock up from behind -.-
and my rx7 fc does
do i need a lil fix on my 04 z the e brake thing ?
Old Aug 18, 2006 | 07:22 PM
masterj26's Avatar
masterj26
....on flat ground.
Chris
yea mine is good on flat ground not too good for much else
Old Aug 18, 2006 | 07:25 PM
nosurf2day's Avatar
nosurf2day
i have the same problem on my 04 Z. I think the cable needs to be tightened.
Old Oct 26, 2006 | 08:54 PM
nothix's Avatar
nothix
whats the best way to adjust the e-brake? Someone mentioned an in-car adjustment. I looked all through the owners manual but couldnt find anything on it. My ebrake applies almost zero brake. Thanks for any help.
Old Oct 27, 2006 | 06:32 AM
VO...'s Avatar
VO...
Administrator
Chris
+1
Old Nov 17, 2006 | 05:45 AM
z2envy's Avatar
z2envy
Originally Posted by kensin0429
weird
and my rx7 fc does
I to have the same problem. I can pull the ebrake when I'm parked and the car doesn't roll but if i pull the ebrake while driving it does nothing. No lock up, and it hardly even slows me down.
Anyone have any info on how to fix this or how to have it adjusted?
Old Nov 17, 2006 | 05:52 AM
nothix's Avatar
nothix
I adjusted the e-brakes when I was replacing my read rotors/pads, and put them almost as tight as they can go. The ebrake works maybe a little better, but still not nearly enough.
Yesterday on my ride home from work that was an accident in 5 o'clock traffic (1 hour moving VERY slowly), and I started hearing tons of brake noise, even when I was braking at all. Either this is my pads hanging up (which doesnt seem good) or my e-brake hanging up. It annoyed the **** out of me.
The weather just got a lot colder in the last few days (-20 degrees almost), so that may have something to do with all the noise.
Either way, I still have no e-brake! and it sucks.
Old Nov 17, 2006 | 06:04 AM
z2envy's Avatar
z2envy
Ya it's really sucks that I can't even use the ebrake for anything other then parking. When I had my honda I could rip the ebrake and it would lock up in a heart beat. No idea what's up with the Z's
Old Nov 17, 2006 | 08:32 AM
Lawn Dart's Avatar
Lawn Dart
Take out the coin holder, and pull the e-brake up until you see the adjustment screw. It's a deep 10mm socket.
Old Nov 17, 2006 | 08:42 AM
z2envy's Avatar
z2envy
Thanks, I'll try that out when I get home from work this afternoon.
Old Nov 21, 2006 | 05:22 AM
guitman32's Avatar
guitman32
From the FSM (edit: just posted the pic):
I did this adjustment this weekend from the rear disc (rotor replacement). It is a bit weird to find the little adjuster at first, but once you know what you are looking for, it is quite easy. To adjust, you turn it full tight (you will know it is full tight...the disc will be locked and will not rotate freely anymore). Do this for both rear wheels. For kicks, go to the e-brake and pull the lever…it will be totally tight and won’t go even one click. Then back off each adjuster about 6 notches. Go back to the e-brake and pull it. It will now have about 6-7 clicks-to-tight. The main thing is to make sure that you back off enough clicks so the parking brake shoes are not dragging on the drum. If you don’t back it up enough, it will be in constant contact with the rotor hub and will cause unnecessary drag and heat buildup.
Old Mar 6, 2007 | 05:57 PM
driftk1d's Avatar
driftk1d
im gonna bump this old thread because my ebrake isnt worth a thign...and im looking at the diagram to figure out what to do but i cant figure out what the second picture is...can anyone help me? or even better someone write a DIY becaue we all know how crappy the Zs ebrake is
Old Mar 6, 2007 | 06:48 PM
nothix's Avatar
nothix
I'm pretty sure the bottom picture is the adjustment on the real wheel. If you take off the rim, you should be able to see the plug on the rotor to stick the screwdriver in for the adjustment.
and just fyi, my e-brake is still dead as ever
Vigman
Nov 17, 2015 04:34 AM
irishfan
Oct 12, 2002 03:24 AM
irishfan
Oct 12, 2002 12:44 AM
troutfishin02
Sep 27, 2002 04:54 AM
