Help adjusting rear Tokico D-Specs
Old 08-21-2006, 01:04 PM
CDR_UK
CDR_UK's Avatar
Default Help adjusting rear Tokico D-Specs
I searched around, and there seems to be no conclusive info on this - I'd like to drill the rear brace to gain access to the tops of my D-Specs so I can quickly adjust them at the track without carrying tools and jacking the car up etc.
Has anybody done this? If so, do you have any pictures? What size drill bit did you use?
I guess the 'X' in this picture is where I need to drill?
Any help is appreciated.
Old 08-22-2006, 04:43 AM
Gilley
Gilley's Avatar
I'm assuming you are referring to the remote cable.
For the G's, on Driver, someone did a writeup on what they did. They basically drilled straight up from where the top of the shock mounts and mounted the remote cable inside the car.
Old 08-22-2006, 05:39 AM
Cux350z
hatersgonnahate
Cux350z's Avatar
well, they make the extension cables. I bought a pair and the quality sucked! stay away fro them.
-they roate freely and dont have a stop or start point so you only are guessing where you start. when i set my shocks, i set them to full firm and then backoff the turns (more consistent and accurate). Well, youll have to remember where you are at in turns and with each adjustment youll be off a bit from the other side.
-during my install one broke! james wie from creativeautoworks said hed take care of me but it hasnt happend
https://my350z.com/forum/brakes-and-suspension/183995-tokico-extensions-review-they-suck-cheap.html
https://my350z.com/forum/brakes-and-suspension/181250-tokico-extensions-where-to-buy-them-online.html
Old 08-22-2006, 05:49 AM
three_fitty
three_fitty's Avatar
+1, got stance coilovers though.
Old 08-22-2006, 09:49 AM
CDR_UK
CDR_UK's Avatar
No, I just plan on using a 3mm allen key (I will just need to remember how many turns I made at the last adjustment - but it's no big deal), and gain access in 2 seconds by lifting off the plastic trim on the rear strut bar. I guess I will go ahead and just drill where I made the 'x' on the picture.
Old 08-22-2006, 09:59 AM
three_fitty
Let me know how it goes.
Old 08-23-2006, 01:17 PM
CDR_UK
CDR_UK's Avatar
I finally found that with allen key I bough that I can make the adjustments from the existing hole:
Old 08-24-2006, 05:57 AM
three_fitty
F**kin awsome bro.
How long does the allen key have to be?
Old 08-24-2006, 09:31 AM
CDR_UK
CDR_UK's Avatar
The allen key I bought (in the picture) is 12cm long, but I think around 8cm long will be fine. It helps having the handle too - because it's easier to see how many turns (or half turns) you have just made.
Old 08-24-2006, 09:39 AM
three_fitty
Did you have to bend it at all? Or does it slide in nicely? Just worried about rounding out the adjuster.
Old 09-03-2006, 12:37 PM
CDR_UK
CDR_UK's Avatar
No need to bend it.
Old 09-11-2006, 02:45 PM
zrdude
zrdude's Avatar
anyone know if this would work in a roadster?
Old 09-11-2006, 03:42 PM
plumpzz
plumpzz's Avatar
Im getting them this week. For street use what setting do you recommend in the rear? Im running 245/275 tire combo so i have medium understeer.
Old 09-11-2006, 10:10 PM
Triple8Sol
Triple8Sol's Avatar
Too bad that won't work in the Gcoupe
Old 09-12-2006, 12:57 PM
Nano
Nano's Avatar
get these --> http://www.good-win-racing.com/mazda/miata/60-1144.html
Old 09-12-2006, 01:01 PM
Cux350z
hatersgonnahate
Cux350z's Avatar
Originally Posted by Nano
read my 1st post in this thread! those things suck for several reasons.
Old 09-12-2006, 02:35 PM
gringott
gringott's Avatar
Hahaha. I still haven't put mine on because of you! I don't want to waste my time!
I will tho, just hope you got a bad set and mine are ok.
Old 09-15-2006, 05:21 PM
Nano
Nano's Avatar
ehm, mine do not rotate freely, I used a dab of blue loktite (just to be sure). And they do have a start point, it's the same as if you were using the key thingy. I found they work great. (if they rotate freely I'm guessing they are broken or are not engaging with the hex bolt at the top of the shock).
And you don't need to remember where you are, you can always count conter clockwise until you are at full stiff.
I agree on creative autowork sucking ***, lol.
Old 09-15-2006, 05:39 PM
aleok
aleok's Avatar
Do they make extensions for regular coilovers?
Old 09-18-2006, 06:00 AM
JCZ33
JCZ33's Avatar
DRILL out the hole nearest to the X, by elongating it with a 1/2" bit. Then you need a long allen wrench to adjust it. The TOKICO tool is too short.
SEARS or your local auto store will have a 3"-5" allen wrench to reach in there.
Works for me.
Quick Reply: Help adjusting rear Tokico D-Specs
