Cerramic brake pads, etc.
Old Sep 24, 2006 | 04:47 PM
glide's Avatar
glide
Default Cerramic brake pads, etc.
Does anyone know if ceramic brake pads are available for the Z? Where?
Can the stock rotors be cross drilled? If not who sells an inexpensive one for a daily driver?
Can adherant pad material be removed with steel wool or solvent?
Are the Hawk HPS pads really a low dust pad? Is there another lower dust pad reccomended?
Wheel wax only protects so much. A lot for one post, I know but
Inquiring minds need to know. Thanks!
Old Sep 25, 2006 | 04:30 AM
Kolia's Avatar
Kolia
Originally Posted by glide
Does anyone know if ceramic brake pads are available for the Z? Where? TireRack ?
Can the stock rotors be cross drilled? If not who sells an inexpensive one for a daily driver? TireRack again. Look for the Brembo replacement rotors. (Why cross drilled anyways?)
Can adherant pad material be removed with steel wool or solvent? What are you trying to do ? Simplest way is the do a proper bed-in. Use some sanding paper if you must. No aluminium compounds.
Are the Hawk HPS pads really a low dust pad? Is there another lower dust pad reccomended? Sounds like the HPS trade dust for noise.
Wheel wax only protects so much. A lot for one post, I know but Was there more to that last line?
Replied in the quote window...
Old Sep 25, 2006 | 07:51 AM
glide's Avatar
glide
Car has 30K and brakes and rotors are fine. I want to switch to ceramic pads to reduce/eliminate the dust. I can't afford new rotors, espesially when the OEMs are still good. Didn't want to put new pads on rotors with adherant brake material on them (a natural occurance) but didn't want to get tham turned and sacrifice thickness, thus the question how can the adherant brake material be safely removed. Tire Rack is a great resource. The Akebonmo Pro Act Ceramic pads looked good (got good reviews, good price) but wanted another opinion on the rotors from someone not trying to sell me something. The cross drilling was for addditional cooling but not neccesary for the street and a bad idea due to possible cracking (per Tire Rack). Thanks!
Old Sep 25, 2006 | 08:15 AM
Kolia's Avatar
Kolia
Good.
Just get new pads and bed them in properly. The old pad's material will be replaced within a week or so.
Old Sep 25, 2006 | 09:30 AM
21112's Avatar
21112
Hawk has new ceramic pads out.
Just picked some up from performance nissan.
Got the rear in and the front's still on the way here.
Old Sep 25, 2006 | 04:44 PM
glide's Avatar
glide
Decided to go with the Akebono Pro Act Ceramic brakes from Tire Rack. They said that I could use a "Scotchbrite" pad to clean my stock rotors. Thanks for the info on bedding in new brakes.
Old Sep 25, 2006 | 10:30 PM
Zincognito's Avatar
Zincognito
I just bought some EBC green stuff brake pads. they are by far the best pads (as far as dust goes) that i have used.
Old Sep 26, 2006 | 05:32 AM
glide's Avatar
glide
Zincognito - Are they ceramic pads? Where do you get these EBC green stuff pads? Anyone else use these to reduce dust? Can you recommend a link with reviews, ie. Tire Rack, etc? Thanks!
Old Sep 26, 2006 | 05:36 AM
sq40's Avatar
sq40
I used Satisfied Pro Ceramic Pads and they were EXCELLENT.
samansharif
Sep 25, 2015 12:31 PM
