New Brakes!! Brembo 14's!!
Old Oct 4, 2006 | 01:31 AM
fucy626's Avatar
fucy626
Brand new 6-Piston BBK for BMW E46 M3 from Brembo
Old Oct 4, 2006 | 06:58 AM
snappy's Avatar
snappy
Thanks for the 411..
Old Oct 4, 2006 | 07:10 AM
jinsei888's Avatar
jinsei888
All directional posts are correct, your rotors are turning backwards
Old Oct 4, 2006 | 07:28 AM
StopTech's Avatar
StopTech
Vendor - Former Vendor
Originally Posted by MustGoFastR
Ok, I asked about my brembo rotor direction in another thread b/c I have mine on the same way (my rotors are Brembo cross-drilled replacement rotors for the OEM Brembos) and you told me that they are NOT directional, due to Brembo's "Pillar Vane" design.
OEM replacement Brembo rotors are usually pillar vaned and not directional. Brembo 2 peice big brake kit rotors do have directional vanes and must be installed on the correct side to promote proper airflow and cooling.
Old Oct 4, 2006 | 07:43 AM
MustGoFastR's Avatar
MustGoFastR
Ah, ok; cool. Had me worried there for a sec.
Old Oct 4, 2006 | 08:03 AM
arizzee's Avatar
arizzee
Sorry for the OT, but I have a bad case of caliper envy
Old Oct 11, 2006 | 10:29 PM
snappy's Avatar
snappy
Default Switched Rotors!!
I went ahead and switched the Rotor direction. Can someone tell me why the Brembo GT 14' Rotor direction is different than most vehicles. Before mounting them the first time, I compared them to my 911 and that rotor was opposite to my current 350Z setting. Go figure 350Z has to be different. Take a look and let me know what you think?
Attached Thumbnails New Brakes!! Brembo 14's!!-brembocloseup.jpg   New Brakes!! Brembo 14's!!-closeup.jpg   New Brakes!! Brembo 14's!!-lowfrontshot.jpg   New Brakes!! Brembo 14's!!-lowrear.jpg
Old Oct 12, 2006 | 06:23 AM
arizzee's Avatar
arizzee
Looks great! Do you have a straight shot, one that is not oblique to the rotors? Reason I ask is that it appears as though this bbk actually moves the caliper closer to horizontal. If that's the case then is should help reduce the infamous pad knockback that plagues the other Z brake setups (I have the stock Brembos, very bad knockback)
Old Oct 12, 2006 | 06:59 AM
snappy's Avatar
snappy
Default Knockback
I haven't experienced the knockback as you stated. Thanks for the heads up!
Old Oct 12, 2006 | 07:38 AM
StopTech's Avatar
StopTech
I posted the answer to the question ealier on in the thread here:
Brembo rotors are directional like ours and can for the most part be installed with the same regard to internal vane direction as listed here:
http://www.stoptech.com/tech_info/faqs.shtml#16
Slot or drill direction cannot be used as a way to determine rotor direction as desings vary between manufacturers. We happen to drill and slot our rotors perpendicular to the internal vanes for structural integrity much like Brembo and some other manufacturers. It is not a 350Z thing as this applies to every kit they offer much like ours. The rotors should be labelled or include documentation on which way they are to be installed and those recommendations should be followed for optimal airflow and performance.
Old Oct 12, 2006 | 08:05 AM
arizzee's Avatar
arizzee
you probably won't experience knockback unless you track your Z or take turns at 2.5 times the posted "recommended" speeds
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
