OEM G35/350z spring rate in kg? Conversion?
Old Oct 5, 2006 | 07:38 PM
TwoK4drSi's Avatar
TwoK4drSi
Default OEM G35/350z spring rate in kg? Conversion?
I found a suspension I want to try but it's in kg and I want to compare or is there a conversion formula I should use? The fronts of these aftermarket coilovers are are 10kg and the rear is 8kg. Any help is appreciated. TIA.
Old Oct 5, 2006 | 08:06 PM
Gsedan35's Avatar
Gsedan35
1 Kg = 56lbs when rounded up.
Oem spring rates are
2003-2004 314/342
2004.5+ 314/427
Old Oct 6, 2006 | 06:23 AM
spacemn_spiff's Avatar
spacemn_spiff
Is it in Kg/mm or Kg/cm ? If its in Kg/mm then Gsedan is right. 1Kg/mm = 55.88 lb/in
Old Oct 6, 2006 | 01:36 PM
Q45tech's Avatar
Q45tech
Has anyone actually measured the as installed, as motion coupled REAL spring roll stiffness. Because the springs are mounted [bottom centerline sits] inboard of the hubs and wheels the real stiffness is substanially less than the published numbers.
Old Oct 6, 2006 | 04:03 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Originally Posted by Q45tech
Has anyone actually measured the as installed, as motion coupled REAL spring roll stiffness. Because the springs are mounted [bottom centerline sits] inboard of the hubs and wheels the real stiffness is substantially less than the published numbers.
Do the numbers have any use to the common man except for comparison between other springs. As long as all the rates are measured the same between manufacturers, why would it matter if you include the suspension leverage, unless you were comparing stock position rear springs to coil over position rear springs.
Chris
350z82
Oct 1, 2015 06:25 PM
