Front and rear pads - same shape/size?
Old Nov 12, 2006 | 07:20 PM
jbum's Avatar
jbum
Default Front and rear pads - same shape/size?
I have an extra set of rear brake pads. I'm starting to hear a squeal from the front brakes and was wondering if the rear pads will fit in the front.
does anyone know if they will fit/work on the front? I doublt it but wanted to make sure.
Also, is it possible to buy just one set of front pads instead of both left/right front sets at the dealer?
thanks.
Old Nov 12, 2006 | 07:39 PM
first350's Avatar
first350
nope. the rears are much smaller than the fronts
not sure what you mean with your 2nd Q: but the front left/right pads are the same, the rear left/right are the same...but front to rear are different. (I've never seen any shops/stores sell front pads for just 1 wheel...they always come with pads for both sides) Hope that answers your quesiton
-Peter
Old Nov 12, 2006 | 07:55 PM
jbum's Avatar
jbum
-Peter
Yes, I was asking if the dealer would sell pads for say just the front left wheel. Hmm... that's too bad. Thanks for the answer though.
Old Nov 13, 2006 | 05:21 AM
first350's Avatar
first350
why do you only need it for the front left wheel?
Old Nov 13, 2006 | 11:02 AM
jbum's Avatar
jbum
Either whoever did the brakes replaced only "as needed" or the front left wore out faster. the front right has about 1/3 life left. the front left's inner pad has about 1/5 left and the wear indicator is sounding off. i know i should really replace both and i will. just wanted to wait for some funds to come through later.
Old Nov 17, 2006 | 06:40 AM
Gilley's Avatar
Gilley
You need to replace pads as a set, left and right.
Old Nov 17, 2006 | 07:10 AM
Nihilation's Avatar
Nihilation
Replace them in sets. I believe the inner and outer pads are both the same however it's not like you can buy each pad individually anyway...
Obadabot
Jun 18, 2023 11:31 PM
