'BRAKE' light goes on under hard braking
Old Dec 13, 2006 | 09:11 AM
STill_matic's Avatar
STill_matic
Exclamation 'BRAKE' light goes on under hard braking
Anyone know what this could be?
I've had the 'BRAKE' light, ABS light & the VDC light go on before, and that was because of low brake fluid. Now when I brake hard, I get the 'BRAKE' light. Any thoughts?
Old Dec 13, 2006 | 02:06 PM
DavesZ#3's Avatar
DavesZ#3
1) Brake fluid is too low.
2) Brake pads are worn.
Old Dec 13, 2006 | 02:15 PM
gringott's Avatar
gringott
Mine went on in the same circumstances when the pads were worn. Replaced pads and no more problems.
Old Dec 13, 2006 | 03:05 PM
STill_matic
Thanks, I'll check the fluid again I guess.
I switched to SS brake lines & changed the rotors & pads, and ever since then, I always have some kind of issue.
Old Dec 13, 2006 | 03:13 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
There was a thread about this exact issue couple of days ago.. Check your brake pads before you refill on fluid.
Old Dec 14, 2006 | 07:20 AM
STill_matic
Wow, could my pads have worn out since June?
I filled up with brake fluid, and the light went away. I must have some leak on the SS lines I put in.
I should probably re-do with some of that plumbers tape on every connection.
Thanks for the help
-D.
Old Dec 14, 2006 | 07:23 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Had the same prob with slightly low brake fluid due to how low my pads were. Check your pads and fluid.
Old Dec 16, 2006 | 06:54 PM
steveiZdaman's Avatar
steveiZdaman
happened to me too...was my brake fluid....topped it off and gone!!
Old Dec 17, 2006 | 07:00 AM
Kolia's Avatar
Kolia
Thanks for the help
-D.
Check your pads before they run out of material you ruin your rotors...
Fluid doesn't evaporates and a leak would be pretty obvious in the brake pedal feel.
Old Dec 17, 2006 | 09:11 AM
MoodDude's Avatar
MoodDude
Not checking your brake pads when your fluid is low is just asking for trouble. And I can run through a set of brake pads in one weekend (although that is 8 hours or more at a track like Sebring).
Old Dec 17, 2006 | 10:25 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
+1
Old Dec 21, 2006 | 03:27 AM
zzz350's Avatar
zzz350
You are technically not correct with this statement, the other guy had a problem with his "break" light
Old Dec 21, 2006 | 03:34 AM
gringott's Avatar
gringott
That is correct, and of course, a completely separate issue. Many people on this forum have problems with the break system, including problems with the break pads. I guess they work long hours and need a break too often.
Old Dec 21, 2006 | 10:03 AM
3hree5ive0ero
Retired Admin
Hahah, so I guess I'm not the only one that sees so many spelling, grammatical, punctuation, etc errors here on the board.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
