eibach springs uneven
Old Dec 13, 2006 | 02:22 PM
nick350's Avatar
nick350
Default eibach springs uneven
installed eibach pro kit 2 weeks ago and the driver rear is lower than passenger rear by about 1/2 inch is this normal or is something notsitting right
Old Dec 13, 2006 | 03:16 PM
Q45tech's Avatar
Q45tech
Is this empty or with you sitting in drivers seat? Full of gas or empty or in between?
Old Dec 13, 2006 | 03:21 PM
35oZephyR's Avatar
35oZephyR
That sounds about right.
I had eibachs and it was the same thing. Switched over to Tein coilovers and it was still slightly lower on the driver's side unless I offset the height.
Old Dec 13, 2006 | 03:25 PM
VIZAGE's Avatar
VIZAGE
Also make sure your on a perfectly flat ground. I've been on slightly angle asphalt (like 10 degrees) and it was 3/4 off. When I drive it on my lift it's perfect, even when I'm in the car. I have the Hotchkis kit.
Old Dec 14, 2006 | 06:43 AM
THE TECH's Avatar
THE TECH
Also, make sure that the springs are seated correctly.
Old Dec 14, 2006 | 07:21 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
my teins do that. I have re installed the springs several times. Still does it.
Old Dec 14, 2006 | 07:24 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Yea, make sure the springs are seated correctly. That could cause this.
Old Dec 14, 2006 | 07:26 AM
drap660's Avatar
drap660
I had a similar issue and it ended up being uneven tire pressure
Old Dec 14, 2006 | 08:00 AM
THE TECH's Avatar
THE TECH
^^That's some jacked up tire pressure.
Old Dec 14, 2006 | 08:18 AM
miester350's Avatar
miester350
I had the Prokit and the driver's side was lower by about 1/4 inch, i now have the sportkit and it is still slightly lower. My freind has Tanabe springs and it is also lower on the drivers rear.... maybe it is just the Z and not the springs???
Old Dec 14, 2006 | 09:09 AM
azula's Avatar
azula
the z's fat a**, i have the eibach pro kit, i may need to measure.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
