Question before i order my parts..
Old Dec 20, 2006 | 08:57 PM
plumpzz's Avatar
plumpzz
Default Question before i order my parts..
Im about to order Tokiko springs/dampeners. I have one last question that no one has really been able to answer, and i dont blame them.
Will I rub so much that I can't drive? I have work emotion wheels, 10'' in the rear w/ a +18 offset. They're 18s. I have a 275/40 kuhmo asx tire on there. They dont run big or small, they run in the middle (reletively..) Will I rub if the car is dropped 1'' as tokiko advertises? I want to avoid getting camber arms for a few months since i already dropped a lot of cash into the car. I was planning on getting SPC rear camber arms/bolts and cusco or SPL's upcoming suspension parts, depending on the quality at the same time, but at a later date.
If anyone knows, please pass the information.
Old Dec 21, 2006 | 03:31 AM
zzz350's Avatar
zzz350
It depends how hard you rub "it". You may rub "it" so hard you won't even be able to walk.
Actually, I have no idea, if you are that unsure, you would be better off buying both the springs and stuff plus have the install done at the same shop. If it doesn't work out, they take the stuff off or change some parts, etc to make it right. It is really the only way to be safe and not throw away your $ potentially.
Old Dec 21, 2006 | 06:58 AM
THE TECH's Avatar
THE TECH
You should be just fine.
Old Dec 21, 2006 | 07:52 AM
plumpzz's Avatar
plumpzz
Okay. I was just making sure. Since the car is a daily.
350z82
Oct 1, 2015 06:25 PM
