Use Caution when using Endless Vita Nuevo brake pads.
Old Jan 10, 2007 | 12:12 PM
SilverJDMCoupe's Avatar
SilverJDMCoupe
Originally Posted by Auto RnD
Also keep in mind that Endless pads do not have an integrated "sensor" like OE pads so you need to physically check them periodically to make sure they haven't worn down too much.
I agree with the other vendors here like Andy and Adam, that this is a street pad and should not be that abrasive. I think they might not have been checked and wore down too far.
you will not hear a "squeal" from endless pads when they have worn down. Please remember to check them.
Rishie
Keep in mind that ALL inboard pads on OEM brembo Brake pads DO NOT have wear indicators what-so-ever. Sometimes the pads can wear uneven, you have to be pro-active on checking your brake pad thickness.
Old Jan 10, 2007 | 02:23 PM
636Racer's Avatar
636Racer
true...because I frequent track days, our track consists of mostly left turns. My right/front pad is worn more than the other.
Old Jan 10, 2007 | 04:25 PM
Nucleus's Avatar
Nucleus
I have read and comprehended all responses. No offense, I am finished with aftermarket pads. They were only used less than 8,000 miles. Lots of pad life left. I checked.
Thanks
Old May 12, 2007 | 02:30 PM
zmansoon's Avatar
zmansoon
Thanks
Hi, I have 27k miles on my Z and just put the Endless Vita Nuova pads on today. I was going to have my rotors turned but O'reilly's said they were too thin to be turned already, I couldn't believe it. I even called the local Nissan dealer and they confirmed it. I went ahead and put the pads on and bedded them in with the old rotors(note: I did not bring in the rear rotors to be turned). Anyway, I am going to go with this setup for awhile and buy new rotors in the next 6 months or so. How many miles were on your rotors when you put on the Endless pads?
BTW, my front rotors measured .871 (inches I think) O'reilly's computer said .866 inches was the minimum and they need to have at least .030 inches they could shave off. The Nissan dealer said the minimum front rotor spec was .886 inches and that I should have my rotors replaced.
I am doing some searches now to see how long rotors have lasted for others on the forum.
Old May 12, 2007 | 03:07 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
why would you waste a brand new, not cheap set of pads on rotors that are clearly shot?
Either replace the rotors (they are not that expensive), or just toss in cheap pads...and deal with a vibrating steering wheel every couple thousand miles till you replace the rotors and pads together
Old May 12, 2007 | 04:31 PM
DavesZ#3's Avatar
DavesZ#3
FSM state 0.866 is the minimum. Dealer probably misread the specs (8 & 6 look similar sometimes). You definitely need new rotors as you are so close to the minimum thickness anyway.
At 27K miles, I'd say you got pretty good wear out of them. It just depends on how hard you are on them, some people get more, some less.
Old May 13, 2007 | 07:17 AM
zmansoon's Avatar
zmansoon
I could replace the rotors sooner...are those pads already shot though since I bedded them in?
Old May 14, 2007 | 12:09 PM
Z1 Performance
Former Sponsor
why not just replace the rotors now, as should be done?
Old May 16, 2007 | 03:06 PM
zmansoon's Avatar
zmansoon
I will do that.
I actually emailed Endless and they said the pads should be fine, I just need to bed them in again.
Old May 16, 2007 | 03:08 PM
Z1 Performance
Former Sponsor
yep you'll be good to go if the pads are new or near no (minimal miles)
Old May 16, 2007 | 03:16 PM
zmansoon's Avatar
zmansoon
Thanks for the advice everyone.
Nucleus, sorry to hi-jack your thread, I hope you haven't totally given up on aftermarket parts!
Old May 28, 2007 | 08:19 AM
Armitage's Avatar
Armitage
So far so good with my Endless SSS. There is little to NO dusting, great initial bite, and my rotors look ok. Only been about two weeks though.
I did all four corners too.
Old May 28, 2007 | 08:23 AM
bizcotch's Avatar
bizcotch
hawks ate my rotors too...
samansharif
Sep 25, 2015 12:31 PM
