tokico d-specs
does anyone have these and what is your feedback because I am very interested in buy a set, but not sure if anyone likes them. Also what is the drop height with this set?
thanks
Jonathan
thanks
Jonathan
thanks
Jonathan
thanks
Jonathan
For the money, the Tokico D-Spec is a great shock. I would match them up with a set of Eibach Sportline, or Pro Kit springs, depending on how much of a drop you want. Great combination IMO.
thanks
Jonathan
thanks
Jonathan
Tokico D-spec shock & spring package 350Z - DSK512
Spring rates in LBS 375f/375r - Linear Springs 1"/1"
Eibach 350Z progressive springs 1”/1” drop
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
Eibach 350Z sportline progressive springs 1.2"/1.2" (notice the wide rate spreads)
Front: 239/400 Rear: 257/435
Peak rates may be slightly higher on the Eibachs, but the D-spec springs have the advantage because they do not have their compromise on performance by having to compress past the softer inital rates or experience sudden rate change. All 4 corners experience the same rate regardless of what your asking of the car, cornering, braking, acceleration, or spin recovery
don't they sell it as a spring and shock kit? also where can I get the whole package for a good price.
http://www.thezstore.com/page/TZS/PROD/PSDC14/23-3998
They are a forum sponcer.
https://my350z.com/forum/members/63861-o.html
