Spring install help/question
Old Mar 23, 2007 | 02:43 AM
SS728's Avatar
SS728
Default Spring install help/question
I'm in the process of installing my s-techs and I got the rear ones done, but the front ones are somewhat confusing. I read TUTs that say I have to remove the strut bar bolts (4) to access the shock/spring assembly, but I think that may have been for a "coilover" install and not just a "spring" install.
What bolts/nuts do I have to remove the get the front springs out with the compressor?
Thanks
Old Mar 23, 2007 | 03:02 AM
Eazzy's Avatar
Eazzy
On the front, the entire spring/shock assy has to come out so the new spring can be installed on the shock, then replaced as a unit
I have yet to have to use a compressor on a spring install
Old Mar 23, 2007 | 05:54 AM
THE TECH's Avatar
THE TECH
You have to remove the strut bar bolts in order to get the shock/spring out.
Old Mar 23, 2007 | 08:00 AM
GTSPEC's Avatar
GTSPEC
GTSPEC
Old Mar 25, 2007 | 02:14 AM
JoeyFyed's Avatar
JoeyFyed
yep
Old Apr 10, 2007 | 07:39 AM
RedBullRR's Avatar
RedBullRR
You Must be Debot from the Movie Friday, because all the Spring Installs I have done (4 total 5 after the Z), with out the compressor you can injure yourself when removing it.
Also I dont see how you get the spring on with out the compressor. How much brut force are you using there?
Old Apr 10, 2007 | 07:42 AM
RedBullRR's Avatar
RedBullRR
Old Apr 10, 2007 | 08:03 AM
THE TECH's Avatar
THE TECH
I have seen people do springs without a compressor. Not the safest way, I grant you that, but nonetheless it can be done.
Old Apr 10, 2007 | 08:05 AM
mx22o's Avatar
mx22o
u can just rent a spring compressor from autozone
Old Apr 10, 2007 | 10:34 AM
Eazzy's Avatar
Eazzy
Then by all means use one.
Old Apr 10, 2007 | 10:35 AM
Eazzy's Avatar
Eazzy
Old Apr 10, 2007 | 11:23 AM
VO...'s Avatar
VO...
Administrator
https://my350z.com/forum/showthread....springs+struts
^^^ someone should make this into a sticky. One stop instruction guide to installing springs on the Z or G.... You can thank me later.
Old Apr 10, 2007 | 11:49 AM
Mazinger Z's Avatar
Mazinger Z
You can rent the spring compressor from any auto parts store. I think it's safer this way. Also, you have to remove your strut bar in order to access the 3 bolts that attach the strut to the car. Keep the struts on the car first, and loosen the top nut on the strut assembly using an extension - it will save you a lot of time and effort this way when you are installing the springs. I did all 4 with the help of a friend. Good luck!
Old Apr 10, 2007 | 11:57 AM
RKnight's Avatar
RKnight
I agree with EASY, by the time the nut is out to the end of the strut when removing, there is little to no tension left on it.
Mattg350z
Oct 2, 2015 06:51 AM
