Help!! HKS hipermax III or Tein Mono Flex?
Old Apr 5, 2007 | 12:51 AM
dedy86's Avatar
dedy86
Default Help!! HKS hipermax III or Tein Mono Flex?
hi!!
i'm looking to buy coilover but still cant decide
i need opinion from u guys...which one is better?HKS hipermax III or Tein Mono Flex.both of them are pretty new and they will cost almost the same, which the Tein a lil bit more expensive. not much review yet for the HKS for now.
Which one is can go lower?i want it to be as low as possible..and i dont do track..mostly for daily driving...
thanks guys!!
Dedy
Old Apr 5, 2007 | 05:35 AM
Fluid1's Avatar
Fluid1
Neither coilover will be worth the money.
Old Apr 6, 2007 | 09:08 AM
adrianko43's Avatar
adrianko43
Get the Tein Basics if all you want to do is lower your car.
Old Apr 6, 2007 | 09:18 AM
Mike Wazowski's Avatar
Mike Wazowski
you must be loaded. You will also need front A arms and a rear camber & toe kit inorder for you to get anywhere close to being aligned.
I would go with the HKS if I was loaded like that though.
Old Apr 6, 2007 | 11:59 AM
MIAPLAYA's Avatar
MIAPLAYA
How did I miss the release of the Hipermax IIIs? I thought they only went as far as II?
Old Apr 6, 2007 | 01:10 PM
Gsedan35's Avatar
Gsedan35
Originally Posted by dedy86
hi!!
thanks guys!!
Dedy
Something tell's me you have really not bothered to read the specs on either product or you wouldn't be considering them. The Mono flex use's spring rates that are far too high for what your after and the III's run a higher rear spring rate setup.
Look at Cusco Zero2, HKS RS or Stance GR+
And, you might want to conser if your needs might be met with a simple shock and spring kit.
Old Apr 6, 2007 | 01:11 PM
Gsedan35's Avatar
Gsedan35
Here's where I learned about them.
https://my350z.com/forum/brakes-and-suspension/254082-coilovers-hks-hipermax-2-or-tein-mono-flex.html
Old Apr 6, 2007 | 01:17 PM
MIAPLAYA's Avatar
MIAPLAYA
https://my350z.com/forum/showthread.php?t=254082
Thanks for that link!!!
nanotech
Oct 2, 2015 05:02 AM
