Starting point for cusco sway bars
Old Apr 24, 2007 | 11:15 PM
ZSpectrum's Avatar
ZSpectrum
Default Starting point for cusco sway bars
What is everyone running for the front cusco sway bar. m gonna be running front/ rear cuscos and tein s techs. Which front setting should I use at first? 20% stiffer or 37%?
Old Apr 25, 2007 | 12:12 AM
Korki Buchek's Avatar
Korki Buchek
It doesn't matter. You put it one way, drive around for a day, then adjust it, drive around for a day and decide.
Old Apr 25, 2007 | 12:25 AM
ZSpectrum's Avatar
ZSpectrum
Sounds like a good idea, is it really that easy to adjust? Should I wait until after the springs settle to do the hard driving on it to detemine which I like better?
Old Apr 25, 2007 | 12:42 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I've had aftermarket sway bars for a little while. I've had the front to the hardest setting and the rear to medium setting. It's all dependent on your personal preference. The installation isn't that hard and I was actually going to do a write up, but I got lazy. Adjusting shouldn't be all that hard neither.
Old Apr 25, 2007 | 12:49 AM
ZSpectrum's Avatar
ZSpectrum
The cusco rears are at a set rate +73 over stock. Does this mean your offering to help install?
Old Apr 25, 2007 | 12:58 AM
3hree5ive0ero
Retired Admin
The ones I had could be adjusted from 107 - 170% stiffer. And since you may be helping with my wheel stud replacement, I may help you out also.
Old Apr 25, 2007 | 01:03 AM
ZSpectrum's Avatar
ZSpectrum
I like the use of may. As long as you tell me when you do it, Ill be there.
Old Apr 25, 2007 | 02:20 AM
3hree5ive0ero
Retired Admin
DIY: Aftermarket Sway Bar Installation (HUGE pics)
^ You can follow my directions if I can't help you out.
Old Apr 25, 2007 | 03:58 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
try it at the softest setting up front first, use it, then go to the stiffer setting if you feel you need it.
There is no magic answer...there are alot of variables involved including your tire, alignment, height, driving style. It's going to come down to user preference.
Old Apr 25, 2007 | 04:00 AM
Z1 Performance
Former Sponsor
not the case actually...you got some bad info passed on to you
Cusco sways are 2 way adjustable up front, either 20% stiffer than stock or 37% stiffer than stock
The Cusco rear sway is not adjustable..it's 73% stiffer than stock
Adam
Old Apr 25, 2007 | 05:16 AM
3hree5ive0ero
Retired Admin
Adam
Oh, the ones I had weren't Cusco's. They were Stillen sways, which are adjustable. And 20% stiffer than stock = 120%, as 100% = stock.
Old Apr 25, 2007 | 06:02 AM
ZSpectrum's Avatar
ZSpectrum
Thanks.
