Installing Front Upper A-Arms - Any Recommendations ?
Old Apr 28, 2007 | 07:28 AM
Kolia's Avatar
Kolia
Default Installing Front Upper A-Arms - Any Recommendations ?
I did a quick searches in the DIY and Suspension sections.
Seems no one has posted information specifically on swapping the front Upper A-arms. Any recommendations on that project ?
I'm hoping I can leave the strut in place and simply loosen all bolt on the A arm to take it out. Is there anything else I'd need to check/do ?
Old Apr 28, 2007 | 07:36 AM
Eazzy's Avatar
Eazzy
Its really just common sense and is self explanitory. You will need a fork to separate the joint, though, I have done so many, I generally reverse the nut and give it one quick rap and it pops. Either way, always thread the nut on the new one before hand and make sure there are no burrs.
Good Idea to put a drop of Red Loc-Tite on the mounting bolts
Im quessing you are putting adjustables on ?
Old Apr 28, 2007 | 07:44 AM
Redfoot's Avatar
Redfoot
If I recall, when I did mine I could not get the bolts out without removing the strut. At the time I had Hotchkis springs on and they have a lot more coils than stock. Its a simple job to do, even if the struts have to come out.
Old Apr 28, 2007 | 07:47 AM
Redfoot's Avatar
Redfoot
I did not need any fork to separate any joint.
Old Apr 28, 2007 | 08:01 AM
Kolia's Avatar
Kolia
I'm mounting SPL Race spec adjustable Arms.
I does seem pretty straight forward from the Nissan manual. But the have a tendency to take the whole car appart the way they explain it...
Sounds like I'll get to use the impact hammer!
Thanks guys.
Old Apr 28, 2007 | 08:11 AM
Eazzy's Avatar
Eazzy
Seems I was able to, on the Z manipulate ( on mine ) the springs to get the bolts out. Prying to the side, extending, so the head would go in the space between the coils etc.
Old Apr 28, 2007 | 11:50 AM
Kolia's Avatar
Kolia
I just looked at the car and it seems like it would be much easier to work with the strut out of the way. I won't be able to get the impact driver in there otherwise...
Old Apr 28, 2007 | 12:20 PM
Eazzy's Avatar
Eazzy
When in doubt, Bite the bullit and make an afternoon of it
Old Apr 29, 2007 | 04:23 PM
Kolia's Avatar
Kolia
Hurray !
It took us 3 hours to do the install. I had to loosen on strut to get the rear body screw in and out (spring was exactly in front of it...) but otherwise a text book install.
I'm getting it alligned on Thursday. I'll be driving the Civic untill then...
Thanks guys
Attached Thumbnails Installing Front Upper A-Arms - Any Recommendations ?-spl_arms.jpg
Old Apr 29, 2007 | 05:06 PM
350Z84's Avatar
350Z84
Nice looking piece. So you did have to take the one strut out?
Old Apr 29, 2007 | 05:11 PM
Kolia's Avatar
Kolia
No not out. I removed the upper mount bolt and then "wiggled" the suspension while my buddy slid the screw in place.
Old Apr 29, 2007 | 07:11 PM
350Z84's Avatar
350Z84
Oh ok, sounds like a pretty simple install. Good to hear, because I think I might need to get some new upper A arms. I only have the eibach kit so I hope they can adjust my camber as it sits with the stock ones.
Old Apr 30, 2007 | 07:38 AM
Chebosto's Avatar
Chebosto
for my cusco A arm, i actually had to remove the three upper pillowball mounts from my coilovers to get to the two 14mm bolts that attach the legs of the A to the car,
other than that, it was pretty simple. ..those SPL arms look like they have multiple pieces.
which one do u use to adjust for camber, is the spindle nut spin out via threaded bolt or do you use the legs to push out?
Old Apr 30, 2007 | 07:56 AM
Kolia's Avatar
Kolia
The camber adjustment is made at the ball mount. The counter thread will extend both ends at the same time. Pretty neat.
Castor is adjusted via de bearings at the body side.
Old May 2, 2007 | 07:51 AM
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
Hi Kolia!
I noticed on the inside points the bearings are slightly threaded out. You want to start with them fully threaded in, and only thread them out as necessary for caster adjustment. We have specs on minimum thread engagement listed here:
http://www.splparts.com/doc/SPLFCAZ33/default.htm
Old May 2, 2007 | 08:01 AM
Kolia's Avatar
Kolia
Cool, I'll be sure to mention that to my mecanic tonight.
m_0g
Jun 3, 2021 10:05 AM
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
