Question about replacing Track Brembo brake rotors
Old Apr 21, 2003 | 03:13 PM
seanrulz's Avatar
seanrulz
Question Question about replacing Track Brembo brake rotors
I'm planning to replace the rotor that I have for my Track stock Brembo. I want a 13' or 14' Cross Drilled/Slotted 2-piece rotor. I thought just replacing rotors would not require any major modification but from the other thread I was informed by Avalon Racing that it is not possible unless I also replace the caliper accordingly.
Does this apply to all makers of rotors? There are quite many brands out there that makes decent qualities of high performance brake rotors and even single of them wouldn't fit in my stock brembo setup? I know brembo also makes Drilled rotor so that it would most likely fit my Track Brembo setup but I'm also looking for another alternatives.
So, basically, do I have to upgrade the whole brake system in order to get the rotor I wanted? This sounds a little bit unrealistic.
Old Apr 21, 2003 | 05:20 PM
seanrulz's Avatar
seanrulz
I believe Brake Pros has a set out for the Brembo rotors.
Enlighten me. I'm little confused about your statement. "Brake Pros" has a set out for the Brembo rotors? What does "Brake Pros" mean? a brake kit within Brembo or is it some other Brake makers? "for the Brembo rotors", do u mean Brake Pros has a set of replacement rotors for Brembos?
Sorry, seems like my English ain't good enough since this is not my first language...
Oh, and can you please tell me what brands make the rotor for Stock Track Brembo setup? Of course, if you know
Old Apr 21, 2003 | 05:30 PM
alphaz's Avatar
alphaz
This is straight off the Avalon Racing site for the Brembos:
TRACK MODEL Drilled / Slotted Rotors
Front
NIS3600XS Avalon PRICE: 425.75 / RETAIL: 556.00
NIS3600S Avalon PRICE: 425 .75 / RETAIL: 556.00
Rear
NIS3601XS Avalon PRICE: 510.75 / RETAIL: 620.00
NIS3601S Avalon PRICE: 510 75 / RETAIL: 620.00
Old Apr 21, 2003 | 05:58 PM
Audito350Z's Avatar
Audito350Z
You can buy replacement rotors for your Brembo brakes. A few online stores are now beginning to sell them (Stillen, Avalon, Gruppe-S).
But, they will not be larger diameter than what you have and they will not be two-piece. The one exception is Disk Brakes Australia... they are working on a stock-sized Brembo replacement that is two-piece.
The opening in your Brembo caliper for the rotor is not wide enough for a rotor larger than 28mm wide. Also, the caliper will have to be relocated outward to accept a larger rotor. I doubt anyone will make a bracket that moves the OEM Brembo caliper since the caliper and mounting bracket are all one piece on the OEM Brembos.
If you want a bigger front rotor, you will have to go with an aftermarket kit like the Brembo Gran Tourismo, Stoptech, AP, etc, etc.
Hope that helps.
PeteH
Old Apr 21, 2003 | 06:47 PM
seanrulz's Avatar
seanrulz
Thanx for the input guys
So..basically I CAN get the Drilled/Slotted but they are not 2 pieces.. and they are same size as the stock which is 12.7...
Well if it is at least 13' I'm fine with it but that .3 inch difference would make things complex? Well as long as there are Drilled/Slotted rotors available for Track Brembo..it ain't that bad afterall...
Old Apr 22, 2003 | 03:05 AM
Avalon Racing's Avatar
Avalon Racing
Avalon Racing
Default That's correct
We replied that there are no "2 piece " rotor replacements for the stock calipers. Replacement rotors in OEM sizes yes.
regards
Old Apr 22, 2003 | 04:32 AM
Zrated's Avatar
Zrated
$936.50 for a set of rotors Have I been under a rock, or is this what a set costs. Is it because they are just out?
Old Apr 22, 2003 | 08:37 AM
Avalon Racing
Avalon Racing
Default That's what they cost
JjL
East Canada
Jun 12, 2019 03:04 AM
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
hardkicks
Sep 20, 2015 12:28 PM
Obeorangekenobi
Sep 11, 2015 07:17 AM
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
