R32 GTR V-spec brakes
depends on the angle they normally mount at if they will work at all.
if they mount in the same location as stock you might be able to get some brackets made up and need custom lines...
they also might not go great with our master cylinder since the total fluid volume depending on piston size in the caliper could be different. you could get a spongy pedal. you would have to find out piston diameters and whatnot and do some math.
