Question about Rotors
Old Aug 11, 2007 | 10:53 PM
Justin350z03's Avatar
Justin350z03
Default Question about Rotors
I'm looking at buying drilled and slotted rotors. My question is: Is there anything I need to look out for? Like what type of metal I'm looking at some on ebay for 175 dollars for a pair but then seen some for 600 for all four. I'm not that educated in rotors so any help would be wonderful
Old Aug 11, 2007 | 11:40 PM
chriskabobbers's Avatar
chriskabobbers
... do yourself a favor and stray as far away from cheap ebay parts as you can.
Old Aug 12, 2007 | 12:06 AM
Ruthless18x's Avatar
Ruthless18x
^ +1
Ebay isnt the best place to buy parts unless you know exactly what you are looking for and what you are getting. As for the rotors there is nothing really special that you need to pay attention to other than make sure you get the correct parts for your application. Brembo/Stock - Front/Rear Etc...
Old Aug 12, 2007 | 06:47 AM
SpeedRcr's Avatar
SpeedRcr
cheap chinese steel ebay pos rotors...you will end up with a nice jackstand base...pay a little more and get powerstops
Many of us have had good luck with inexpensive rotors. For critique and photos search r1concepts.
Old Aug 13, 2007 | 06:48 AM
Q45tech's Avatar
Q45tech
There are dozens of quality and hardness grades of cast iron used to pour rotors. Without xray crystallography and similiar lab test hard to tell what quality was used much less how the various after pour quenching and finishing was carried out.
Even to experts things can look the same without rigorous testing.
This should help you understand the basics:
http://www.sae.org/events/bce/tutorial-ihm.pdf
Find out the SAE J431 Grade G7 to G13 of the rotors you plan to buy?
http://www.pmt.usp.br/ACADEMIC/antschip/freio.pdf
http://www.scielo.br/pdf/mr/v8n4/27625.pdf
http://delphi.com/pdf/techpapers/1999-01-0142.PDF
Old Aug 13, 2007 | 06:39 PM
Justin350z03
Thanks for the help guys, Talk to Sam from R1Concepts hes on the forums.
Old Aug 15, 2007 | 06:10 PM
Ztalker's Avatar
Ztalker
i got R1 drilled /slotted...no different than oem, no rust either.
Old Dec 9, 2007 | 08:22 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
i bought s2k antenna from ebay, looks good
Old Dec 10, 2007 | 04:35 AM
Z04's Avatar
Z04
um, what does that have to do with rotors?
but back on topic (since this got resurrected for such a dumb comment) even some reputable brake places sell crappy rotors as well. I would check around, do a search and see what others are using. or just get a stoptech stage 1 or 2 upgrade. might cost a bit more than what you was going to spend, but when it comes to things like the brakes it doesn't hurt to make sure they are done right the first time. saves a lot more in the long run.
Old Dec 10, 2007 | 09:37 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
from top couple post was talking about ebay buy. so
Old Dec 12, 2007 | 06:23 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
do yourself a favor...pick up a Stoptech Stage 2 kit - includes rotors, pads, lines, fluid, from a top notch company that supports our community, and who ONLY does brakes (and does it as good as anyone)
http://www.z1auto.com/prodmore.asp?m...ng&prodid=1805
Old Dec 12, 2007 | 11:08 AM
gothchick's Avatar
gothchick
/\ +1. Stoptech stage II is top notch. Got it on my car & love it.
issyz
Jul 2, 2017 03:04 PM
samansharif
Sep 25, 2015 12:31 PM
