Lowering Question
Old Aug 26, 2007 | 08:35 PM
Z4Zoro's Avatar
Z4Zoro
Default Lowering Question
I am interested in lowering my 350z a small amount in the front and more in the back.
Is it neccisary to buy new shocks or a camber kit righ away? Are there people having no tire wear problems with there springs?
Old Aug 26, 2007 | 09:09 PM
whitecel's Avatar
whitecel
Some springs may need camber kits while others you don't need. After owning and doing suspension mods to many cars, anytime you change a spring to make it lower, it will wear out the stock shocks quicker than if you were to keep it stock. In some cases, the wear is minimal while other times it is drastic. As for camber kits, it all depends on the drop and what your alignment specs were before you installed the new springs. If you want a small drop, I'd go with cutting the springmount. If you want a little more, go with the tanabe gf210 or the eibach's. I plan on going with the tanabe or the eibach's once my warranty is up.
Old Aug 26, 2007 | 09:40 PM
Z4Zoro's Avatar
Z4Zoro
Will cutting the spring mount cause suspension noise?
Old Aug 26, 2007 | 09:48 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
If u mean cut the springs like cheap way DONT DO IT. did it on my cavy and WOW cost me loads of money to fix.
Old Aug 26, 2007 | 09:52 PM
Z4Zoro's Avatar
Z4Zoro
I kind of wanted to get away cheap without changing out shocks/struts. I have no problem buying and installing the springs; just concerned the the shocks would get alot of work and the alignment would be off without chamber kit. Wondering what most people are doing.....Maybe its worth the extra buck and go for coil overs?
Old Aug 26, 2007 | 11:17 PM
whitecel's Avatar
whitecel
sorry i should've clarified on the springmount. I mean cut the rear...
https://my350z.com/forum/brakes-and-suspension-diy/246148-diy-cutting-rear-springmount-aka-the-springmount-mod.html
Old Aug 26, 2007 | 11:24 PM
soleil's Avatar
soleil
NolaZcc
dude, do not cut ur springs...i have the tanabe gf210... i need to get an alignment...but so far its not bad....but i heard with the tanabe springs u can get it close to specs again...but once again do not cut ur springs
Old Aug 28, 2007 | 08:43 PM
Gsedan35's Avatar
Gsedan35
No
Old Aug 28, 2007 | 08:52 PM
Gsedan35's Avatar
Gsedan35
The answer get's you into the complicated word of, at what point will not being in oem alignment specs will I have excess tire wear? At the .8" and beyond drop point most Z's start to not be within oem alignment specs. So what's your idea of a "small amount in the front and more in the back'? How much drop do you want to be happy?
Will you need new shocks, most often no. BUT, is your car a 03 or 04, if yes I would recommend different shocks.
issyz
Jul 2, 2017 03:04 PM
