help!!! front strut got stuck lol
Old Sep 13, 2007 | 02:24 PM
Carter86's Avatar
Carter86
Default help!!! front strut got stuck lol
What should I do? I took off the lower control arm and other bolts but it still doesnt wanna come out. I just found a link of G35 NYC so imma try that. Any advice though?
Old Sep 13, 2007 | 02:51 PM
terrasmak's Avatar
The balljoint on the upper control arm , pull that and you can flex the lower down a little more till the strut comes out.
Old Sep 13, 2007 | 03:06 PM
huyrua's Avatar
huyrua
use a spring compressor
Old Sep 13, 2007 | 03:30 PM
Gsedan35's Avatar
Gsedan35
You won't find the answer at that site. You need to unbolt the sway bar end link from the suspension arm, pulling the bolt out in the process. Then you need to pull the cotter pin that that is in the bolt that secures the upright to the upper camber arm, then remove the nut. The upper arm will likely be stuck, use a rubber mallet to gently unstick it, carefull once the upright and upper arm seperate the entire suspension will want to fall towards you. You will now be able to push down on the lower suspension arm and remove the shock/spring assembly.
Old Sep 13, 2007 | 07:12 PM
Carter86's Avatar
Carter86
Thanks for all the help guys but i cant loose a few of the bolts so I'm gonna flat bed the car somehow and take it to shop. Im used to AE86 but not 350z. I guess I underestimated the Z lol
Old Sep 13, 2007 | 07:40 PM
Gsedan35's Avatar
Gsedan35
You can do it. The first thing you need to do is use a floor jack and lift up on the lower control arm until you get just enough tension off the end link bolt that is threaded threw the lower control arm. Once you get that bolt out you can move up to the bolt holding the upright to the upper control arm and you'll be free and clear. If for some even seperating the upper arm from the upright doesn't work, then use a spring compressor to releave the tension on the spring.
Old Sep 14, 2007 | 08:54 AM
Carter86's Avatar
Carter86
okay i got the shock back in but im having a trouble over putting the lower control arm back in
Old Sep 14, 2007 | 10:44 AM
RedBullRR's Avatar
RedBullRR
Use a Jack and place it rite at the corner of the shock and pump pump pump it up. LOL, nah but seriously it worked for me. Also unbolting the ball joint up top helped.
Old Sep 14, 2007 | 08:53 PM
Carter86's Avatar
Carter86
Thats what I did! I used rubber hammer too. Thanks for all the help guys. Now, I'd rather take it to a shop to get it done lol I can't believe I struggled this much over suspension stuff!!!!
Old Sep 15, 2007 | 07:28 AM
jOeL350z's Avatar
jOeL350z
if u dont have any spring compressor then ur best bet is either get one of ur buddy whos at least 200lbs and a pry bar and that should take care of the rest. Pry them first to see if they are moveable then have ur buddy step on the disc brake then pry them out...
Old Sep 15, 2007 | 10:24 PM
Mazinger Z's Avatar
Mazinger Z
Take the factory jack and put it between the bottom of the inside of your car and the upper a-arm. To prevent damage, put a thick towel or some sort on top of the factory jack and the bottom of the inside of the car. Raise the factory jack slowly and you can probably take out the strut. If this doesn't work, go borrow a manual spring compressor from auto-zone and try again. It should come out no problem.
Old Sep 16, 2007 | 12:19 AM
rx7/350z's Avatar
rx7/350z
funny i remember looking at the same thing 2 years ago +1 for swaybar endlink removal
Obadabot
Jun 18, 2023 11:31 PM
