About Springs, Lowering and shocks
Old Sep 29, 2007 | 09:34 AM
Pepuko's Avatar
Pepuko
Default About Springs, Lowering and shocks
Hi everybody.
First, sorry for my english, Iīm from Spain
Second, Iīve been trying to search for this question and I have been reading theads for 45 minutes, and I donīt have any idea what to do.
After reading all of that information, my question:
I want to lower my 350z w/o hurting factory shocks. I donīt want to change my shocks soon, and I donīt want to break them.
I have read about two. Which one do I choose?
1. Swift Sport Springs 03-06 Nissan 350Z
Swift made Sport Springs keeps your quality ride you get from showroom, and adds a sporty feel and lower ride height for sport driving enthusiasts and style minded drivers who demand only the best.
Swift did not start developing Sport Springs by trying to drop the ride height. Unlike others who only care about style, Swift approached to create lowering springs with 3 rules.
1 Keep or improve a smooth comfortable ride.
2 Increase handling, control, and performance.
3 Lower the vehicle within the each vehicle’s usable stroke.
Swift developed each Sport Springs application based on each vehicles unique characteristic. So a Luxury car will keep its luxury ride, and sports car will handle like a sport car.
Drop Rate(F/R): 0.8"/0.6"
2. Hotchkis Sport Coil Springs
(What are those bars for?)
Hotchkis Tuning Sport coils offer the performance you seek, and the comfortable ride you deserve. Made from cold wound silicon steel, our springs are linear rate, and are powder coated seabring silver.
Front Front 9/16" (15mm) Drop
340 lbs/in
Stock 310lbs/in
Rear 3/4" (19mm) Drop
330 lbs/in
Stock 350 lbs/in
3. Any other suggestion.
I hope you can help me. Thank you very much!!!!
Old Sep 29, 2007 | 10:40 AM
Mazinger Z's Avatar
Mazinger Z
No matter what, lowering your car on stock shocks will soften them up and eventually you'll have to swap them out. I say instead of the TVS1, go with a set of springs only and get some tokico's or koni yellow's. You'll be much happier and you can always add the sway bars later.
Old Sep 29, 2007 | 10:51 AM
Pepuko's Avatar
Pepuko
Thank you for your answer.
I suppose that tokico's or koni yellow's are shocks.
What are the sway bars for?
Old Sep 29, 2007 | 10:52 AM
AWDBall20's Avatar
AWDBall20
the springs are all going to be pretty similar, lots like tanabe gf210, I personally have Eibach and so far they are nice. But bugsbunny is rirght eventually you will have to replace your strut.
Old Sep 29, 2007 | 11:00 AM
BaTMan_4's Avatar
BaTMan_4
Out of those 2 options of springs you are saying i would go with the Hotchkis. Another suggestion i would say Tanabe but I'm biased Depending on how much punishment the shocks get once you drop it they should last you quite a while before giving out.
Old Sep 29, 2007 | 01:51 PM
Z1NONLY's Avatar
Z1NONLY
03-04, I would go with Hotchkis. 04.5'+ I would, and did, go with RS-R's (Ti2000)
The reason I put different names with different model years is the spring rates. The Hotchkis rates are pretty close to the 03-04 stock spring rates and the RS-R's are close to the 05+ rates (although I'm not sure about the 07 stock spring rates.)
Old Sep 29, 2007 | 01:53 PM
r_seng's Avatar
r_seng
swift sport springs are your best bet. im pretty sure they don't go lower then an inch. plus they are a reputable (sp?) company for making springs and coilover springs.
Old Sep 29, 2007 | 07:54 PM
Gsedan35's Avatar
Gsedan35
Originally Posted by Pepuko
Hi everybody.
Neither one of your spring choices are that much stiffer then the oem springs or drop the car a great deal as to cause the oem shocks to wear out. You have made two great choices in linear springs. The Swift springs are more expensive then the Hotchkis springs, you'll need to be able to justify their cost. It should be about the right choice for the right reason's, not a popularity contest where well thought out choices aren't alway's what other's do.
Just to say it, it's my understanding that all european deliver 350Z's have the revised suspension, so I can't recommend replacing the shocks because you have a U.S. 2003 or 2004 car.
Old Sep 30, 2007 | 09:01 PM
phorbo007's Avatar
phorbo007
The hotchkis springs are very popular and a lot of members run them w/o replacing the shocks. Also because of the subtle drop, most people get away w/o needing camber kits. I'm actually getting my Hotchkis installed next weekend.
Old Sep 30, 2007 | 11:04 PM
Pepuko's Avatar
Pepuko
Sorry. I forgot to say that my Z is a 2005+ Z (300 hp). Does this matter? I mean, is there any difference between 280īs and 300 hpīs suspension?
Old Oct 1, 2007 | 07:12 AM
Gsedan35's Avatar
Gsedan35
No difference between 2005 and 2007. In the U.S. their is a difference between 2003/2004 and 2005/2007. It is my understanding that all european delivery 350Z's ride on the same suspension as our 2005/2007 cars. Of course knowing shock part numbers would be the ultimate test. In any event knowing you have a 2005 means you have decent factory shocks.
Old Oct 1, 2007 | 10:29 AM
leykias's Avatar
leykias
go swift.
Old Oct 18, 2007 | 07:39 AM
Alz350z's Avatar
Alz350z
Are you saying that all z's that were delivered to the US ride on the same suspension from 2003 thru 2007 oppossed to z's sent to other countries? In the first sentence you say their is a difference btw 2003/2004 and 2005/2007 I'm confused.I misunderstood your statement know need to explain I understand now
Old Oct 20, 2007 | 07:34 PM
Gsedan35's Avatar
Gsedan35
Because I wouldn't want you or anyone else to be confused, I'll clarify.
It is my understanding that all european deliver 350Z's ride on the same suspension, the one we know here as the "revised" suspension.
The difference between suspensions 03/04 vs 05/07 applies only to USDM production and was not ment to confuse the issue about european 350Z's.
USDM 350Z's for model years 2003 and 2004 have the original suspenison. Midway into 2004, Nissan did a running change where they revised the suspenion. This revision features new shocks with less compression dampning and more rebound control. Rear shock dustshield/bumpstops were also redesigned. Rear spring rates were increased 25% from 342lbs to 427lbs. And front sway bar strenth was upped 17% courtesy of thicker walls in their hollow construction.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
