Inner Tie rod replacement
Old Nov 10, 2007 | 03:23 PM
kevin8086's Avatar
kevin8086
Default Inner Tie rod replacement
Just bought some Tein Tie rods and would like to know if there is a special tool you need to replace the inner tie rods? i'm pretty good when it comes to wroking on cars but have not tried tie rods yet and i know sometimes you need specialty tools to remove components.
Old Jan 4, 2008 | 03:56 PM
malchemy's Avatar
malchemy
There are technically no special tools required for replacement of tie rods but it can help to have a tie ro separator. This is for separating the outer tie rod from the rest of the suspension. You can rent a kit from most auto parts stores and some of them have special daily rent kits specifically for this part. I would recommend the separator because it makes things a lot easier. For the removal of the oem inner tie rods you will need to immobilize the steering rack. I use a vice that happens to work for the purpose. If you go this way make sure that it will fit and that you protect the rack from metal on metal abrasion.
Old Jan 4, 2008 | 03:57 PM
malchemy's Avatar
malchemy
oh and I have done this on an Infiniti G35 not a z but all steps mentioned above apply to your model...
aboodi
Oct 28, 2015 02:07 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
