anyone thought about cutting stock springs.
Old Dec 11, 2007 | 05:39 PM
kcobean's Avatar
kcobean
Chris,
If you're on a budget, you might consider the Eibach pro-kit springs. I had them on my Z, the drop is just about an inch, and it's PLENTY low enough. They're a progressive rate spring, and I felt the ride quality was excellent. I would advise AGAINST going more than an inch because you run a HIGH risk of not being able to get the car to align properly without a camber-kit which will run you another 400 or so dollars.
And you can get 'em shipped for well within your budget.
ETA: Cutting your springs is a bad idea because the stock springs are 'flattened' at the ends to sit in the cups better. If you just whack off one end, they're not going to sit right, and you may even stand the chance of a spring separating from a cup....that would be bad.
Old Dec 11, 2007 | 05:56 PM
tekk's Avatar
tekk
i HIGHLY recommend you leave your car stock until you can allocate more funds towards lowering.
first off, cutting springs is a bad idea. you will ruin the ride of the car and you will ruin the shocks. so you'll need either springs and shocks or coilovers. but then you're not done...
lowering the car will increase tire wear if you dont adjust for it, which means buying more tires, which means spending a lot more money.
alternatively you can buy a camber kit, which requires purchase and install... but again that's several hundred dollars.
honestly id leave it stock. jmho...
Old Dec 11, 2007 | 06:23 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Eibach or Tannabe's I believe are the lowest springs. Well under the $350 budget. If you still decide to cut your springs then please don't bother asking anymore questions on the forum.
Old Dec 12, 2007 | 05:20 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
i thought that when i had Civic
Old Dec 12, 2007 | 06:25 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
please just dont do it...there is no sense in taking a great car and wrecking it. Upgrade smart and sensibly with the end goal making things better not worse
Old Dec 12, 2007 | 06:55 AM
ghost's Avatar
ghost
Originally Posted by istan
Just get Springs... No need to see a Z bouncing around on the streets.
You must've never done it.
A Z might have different spring rates, but i've had three cars with cut springs, and they rode just like aftermarket springs.
Old Dec 12, 2007 | 08:04 AM
Changvi's Avatar
Changvi
LOL...i just could not stop laughing when i saw the title. This is a Z forum, not a Honda. Thanks...FYI, do a search on cutting coils and you will discover that how stupid the idea is. Good luck.
Old Dec 12, 2007 | 08:07 AM
Driven1's Avatar
Driven1
Professional
No way. If you honestly think thats true. I suggest on doing some reasearch on springs and spring rates.
Old Jan 5, 2008 | 09:34 PM
los06z's Avatar
los06z
Old Jan 27, 2008 | 08:24 PM
Goku350z2007's Avatar
Goku350z2007
don't be a ricer, get coil springs
Old Jan 27, 2008 | 08:38 PM
kcobean's Avatar
kcobean
Well it's not like the Z comes stock with leaf springs...
Old Jan 28, 2008 | 08:00 AM
mdracer76's Avatar
mdracer76
Dont cut your springs.. just take them out. that should be good for a pretty sweet drop.
Old Jan 28, 2008 | 08:03 AM
gothchick's Avatar
gothchick
Ricer = teh suxxor! Don't cut your springs.
Old Jan 28, 2008 | 10:28 AM
kcobean's Avatar
kcobean
Yeah as in drop your colon right out your a-hole the first time you hit a bump!
But hey, the car looks killer with all that negative camber.
Old Feb 6, 2008 | 07:30 PM
Goku350z2007
oopss i meant to say coil overs
Old Feb 6, 2008 | 07:37 PM
badkarma85's Avatar
badkarma85
Might as well get some altezza lights, ill-fitting + unpainted wide body kit with +50 offset 7.5" rims from eBay.
Don't forget to nail a GT wing on the rear which sits 3ft off the trunk.
I think that's precisely the look you're after.
Old Feb 7, 2008 | 09:06 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
This thread is embarrassing to even see on the boards. I vote for deletion.
+1 for deletion
Old Feb 11, 2008 | 07:23 PM
  #38
ladyzed's Avatar
ladyzed
Originally Posted by Driven1
You have to be kidding me! Sell the car if you have even considered this option...Honestly...thats about the best advice I could give you.
It will RUIN the ride and persformance of the car. Period. If you HAVE to go cheap, pony up for some cheap spings. DO NOT cut or heat compess your springs.
OMG. People still consider HEAT COMPRESSING THEIR SPRINGS???
That has to be the most dangerous modification to your suspension, let alone cutting the coils. Ya, I've heard people cut a wrap (approx 1.0"), and had ok results, however, your suspension performance will suffer. It will be bouncy, not able to compress properly, and noisy.
Justin100
Nov 25, 2021 06:26 AM
Tochigi_236
Sep 27, 2015 03:40 PM
