F & R brakes
Originally Posted by Seamaster
If I upgrade my F brake to a bigbrake kit, can i use the
stock F brake on my rear? thanks
It will work fine... I run an AP Racing 14.25" 6 piston kit up front and have non brembo ST Stage II parts in back. Talk about a size difference!
Eventually I will upgrade to an AP kit for the rear though, mostly for aesthetic reasons.
A cheaper alternative to the BBK conversion (if aesthetics is all that you're after), I think, would be to powdercoat in flat black the calipers and all the rotor area that is not in contact with the brake pad, to prevent the rust from showing. I am planning to do this when my current rear pads are worn off and it's time for replacement. I'll let you guys know how the finish holds up.
^ The color is not an issue. The stock rear calipers have already been painted black, and like I posted I am running a stoptech stage II kit in the back (rotors only have a small ring of rust near the hub, the rest is coated). Mainly what I find problematic is the huge size difference in rotor diameter between the 14.25" AP rotors up front and the 11.X" stoptechs in back. From a side angle it looks pretty ridiculous. Like comparing a dinner plate to a compact disc.
Originally Posted by Z04
the OP was talking about taking the OEM front calipers and putting them onto the rear, not leaving the stock rears in place with a BBK front
The answer then is a decided "no".
