Cutting my Eibach Springs...I know I know but this should work!!!
on
I can't believe I am writing this, but I am super super **** about getting the perfect stance. Well my Eibachs are 99% there but the front needs to be 1/4" lower to suit my needs. Why not coilovers you say??? Well I really like how my Z rides and I have never found a set of progressive rate springs in a coilover. If there was I would buy it.
So.....If I remove my front springs...start at the bottom coil...where it ends and chop off about 1 linear inch of spring. I do not see how it will effect the ride at all. I have the same spring rate up top and downlow. Coil density has not changed. The only difference is the strut will now be compressed 1/4" more than before.
This is a 3-D scaned rendering to scale of what I am talking about!
![](http://i86.photobucket.com/albums/k84/yusoslo/myspring.jpg)
on
1 Post
WTF is with all these stupid cutting the springs threads. you do realize that by cutting the spring, you not only compromise the integrity of the spring, you also make for a dangerous situation which can result in damage to your car. but whatever, it is your car and if you want to take the cheap way and damage a very important component ofyour suspension, then do it. i will just wait for the inevitable "my suspension feels like crap" or the "i damaged my suspension, and warranty will not cover it" thread that will be posted.
on
OK, first of all I am not Ghetto! I have plenty of money to do this the right way....but I want a comfortable ride......Show me a coilover setup with progressive rate springs..my Eibachs ride better than stock.
I have a set of 2k coilovers in my garage now. I also have a set of custom built RE-Amenyia coiovers for my RX-7.
So now that that is out of the way, tell me how this will effect ride quality. If at most I am removing 1/5 of 1 coil's overall circumfrence. How can this be damaging...please do tell.
on
1 Post
on
I can see Z04's point of view. Seems like you will be changing the spring rate if you take any part out. I wouldnt do it. Then again Im not going to get mad at you if you do
Good luck.
![Smilie](https://my350z.com/forum/images/smilies/smile.gif)
on
OK I knew I was going to get some flaming. I just still havent seen any evidence that loosing 1/5 of 1 coil will effect the spring.
to ZO4.......Spring rate is determined by coil diameter, coil spacing, desity of the material etc...not the lenght of the spring. Do you think that springs come out of a mold??? NO they are extruded and spun and then cut to length and then coated in polyurathane. So if Eibach cut them I can cut them. If I cut a piece of plywood or I cut a peice of Rebar in half...do I comprimes the material? No. The struts are already seeing a 1.2" compression...so is there a magical # that if I go another .2" they will implode??? If Chip Foose cuts Hotchikis springs on his TV show I think the company would throw a **** fit. I see Chip Foose cutting springs all day long.
AS I said before.....show me a height adustable coilver with stock or better ride quality and I WILL buy it. And I doubt there is a progressive rate coilover on the market.
Cutting a measure of the dead coils out is one thing, painting a bull's eye on yourself and doing this thread knowing full well the shot's members here will take is totally different. Free country and all but I just don't see that is was a good idea.
Progressive springs ask too big of a vise, why someone would want them on a sports car as a measure to overcome sub par dampning/meek piston stroke is something I'll never get, especially knowing what things are like when you don't have those issues. Kw V1, 2 and 3 coilovers have the progressive springs your fond of. Figure out how to run helper springs on the front of Bilstein Pss and Pss9 coilovers and you can have progressive springs their as well.
on
-I will look into the KW coilovers.
-I don't mind the flaming...but making comments that have no explination is what gets me, but I know you have to take the idots with the people that know what they are talking about. They didnt ask for my IQ when I signed up for this board....so who knows what Z04's level of knowledge really is...or anyones for that matter
-I have this pretty logical thought process. My 350Z is a sports car...it is my daily driver....I race it on the weekends twice a month. So 90% of its life if commuting. I can sacrifice .2 of a second at the track so that I can comfortably enjoy my car 90% of the time. Makes sense?
You should realize it's not just a E.T. numbers issue. At the limit behavior and overall car feel is compromised to varies degree's totally dependent on the spreads between initial and final rates and at what point in travel you suddenly change rate. Though it should be said that the front progressive springs on the KW coilovers are a tapered design and will not change rate suddenly, not to mention that their rate spread is really small. Get the dampning right and shock travel right and you don't have to do the compromise.
Finally some go
on
very humorous.
I still don't think it ricerish. So whatever to the Civic comments...and BTW 99% of us have had a civic at one point.
I am just going to beat a dead hoarse over this...it isnt like I am heating up stock springs, or chopping off 2 coils of the stock spring.
Who here that has chimed in has an engineering degree? No ok then. I am well knowledged in mechanical engineer since I have a Master's in it, so someone show me PROOF.
I want PROOF instead of BS its ghetto to cut/tailor your springs.
very humorous.
There are many coilovers that are comfortable and will drop almost the same amount. Tein has a CS version which is pretty soft but also a coilover setup, you might want to look into it.
I still think my fat chick idea will work.
![Big Grin](https://my350z.com/forum/images/smilies/biggrin.gif)
on
1 Post
as for you progressive spring coilover, here is a few:
Bilstein PSS and PSS9
KW Variants
H&R coilovers
very humorous.
