Crack in piston dust boot on Stoptech caliper?
Old Dec 11, 2007 | 11:54 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
Default Crack in piston dust boot on Stoptech caliper?
I bought a set of stoptech ST40 332mm BBK from a member on the forum and I noticed a crack in the rubber boot that holds the piston on 1 of the piston. Its cracked I'd say 75% all around the rubber boot (not sure if I'm using the correct terminology) and I was just wondering if this is something I should be really concerned with.
I'm not tracking the car or anything like that but want to make sure this isn't a problem I need to be concerned about. Thanks guys!
Old Dec 12, 2007 | 03:39 AM
Russ@Z1's Avatar
Russ@Z1
It's more of a dust shield. The more dirt/dust that gets in there, the quicker the wear and tear will be. I would assume you could purchase a new cover and replace the bad one. Try calling StopTech and checking.
Old Dec 12, 2007 | 07:26 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
Thanks bro I will Glad to get some good ifno though I was getting kinda worried.
Old Dec 12, 2007 | 03:54 PM
mthreat's Avatar
mthreat
Fairly common, they sell replacements here:
http://www.zeckhausen.com/StopTech/c...es.htm#Rebuild
I'm just about to rebuild my calipers to replace these seals myself...
Old Dec 15, 2007 | 08:39 PM
Eazzy's Avatar
Eazzy
Thats a cool site ----The Dust covers are not only for Dust and Dirt but also for moisture. A caliper piston has to remain spotless
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
pr_350z
Oct 1, 2015 05:03 PM
