Big Brake Kit Picture Thread!!!
Old Sep 11, 2012 | 11:04 PM
  #841
SDGenius's Avatar
SDGenius
swapped back to my Project Kics lugs
Old Sep 12, 2012 | 07:31 AM
  #842
alfhasg35's Avatar
alfhasg35
^^ nice mark..
Haha. Seems like I find these threads RIGHT after u post.. I'll post mine a lil later so it doesn't looks like I'm stalking.!!! Lol
Old Sep 12, 2012 | 07:35 AM
  #843
SDGenius's Avatar
SDGenius
^bwhahahahahahahahhahahaha Alf
Old Sep 19, 2012 | 07:54 PM
  #844
ronn1's Avatar
ronn1
Originally Posted by jerryd87
if your abs is not activating when you have a bbk then you either ****ed it up or your have reduced your braking power. the computer has absolutly no way to tell you put a bbk on the car it monitors wheel speeds to activate the abs. if it actually increased your braking power then it would be activating MORE. learn how brakes actually work, they ARE engineering with the same piston volume so that you can swap in just a front kit without the rear next time you wanna try claiming they arnt call the manufacturers tech department. go ahead and take your car to a place who has the actual tooling to measure the performance of your brakes(i know ssbc will do it for a price.) your expensive *** bbk isnt going to produce any more clamping force then stock without a kit for a different vehicle.
now you would think that more area on the brake pad would result in more clamping force but that follows the same failed logic as a bbk increases your braking power. sure the pads are longer so you would think there is more area, BUT the force applied to the pad itself is the same as stock, you dont have a smaller master cylinder to increase pressure, and unless you upgraded to a different booster or longer pedal your not getting anymore pressure there either. so you have stock pressure at the pad again call the manufacturer since obviously you have no idea what your talking about and dont believe me. so what happens when you take the same pressure and apply it to a larger surface area.................... oh **** less clamping force. so any benefit you gain from increased pad area is negated by itself from the loss of clamping force, resulting in a stock performing kit.
the oem pistons might be a single piston but they are much much much bigger then stock(and actually 06-08 are dual piston front)
sorry i know you agree they dont help you stop sooner but your post is just flat out wrong.
also that link your talking about is repeatedly talking about front and rear changes as well as swapping calipers made for different vehicles. the 350z kit is made so you can place it on the front of a car without the rear because the piston volumes are the same.
The article clearly shows that switching to the BB kit on the fronts alone improved stopping distances on both the cars tested. The reasons are due to BOTH proper brake balance F/R and increase in brake torque with larger rotors. Pads of course may have played a role as well.
"As before, we did twenty stops, the first ten from 60mph, followed by six stops from 80mph and then four stops from 100mph. The difference was noticeable even at 60mph. The stops were several feet shorter than the stock brakes and the rotor temperature was 155 degrees cooler after just 10 stops. From 100mph, the car stopped 4.3 feet sooner."
Old Sep 19, 2012 | 08:57 PM
  #845
mikes10's Avatar
mikes10
meh
Size:  990.0 KB - trackday grasshopper -
Old Sep 19, 2012 | 09:16 PM
  #846
mikes10's Avatar
mikes10
Originally Posted by Robert_K
Big Brakes do not help you stop sooner. They help displace more heat. Your pads and most importantly your tires help you stop.
i like to think reverse helps you stop -
Old Sep 19, 2012 | 09:31 PM
  #847
rallysportdirect's Avatar
rallysportdirect
Vendor - Former Vendor
Now please don't go hating as I know this isn't a Z or even a Nissan for that matter, but I am very proud of our brakes on our shop car with the sizing and specs being very similar to the what you would see on a Z for the Project Mu BBK.
Car: 2011 Subaru STI
BBK: Project Mu
Front Caliper: 6 Piston
Front Rotor: 355x28mm
Rear Caliper: 4 Piston
Rear Rotor: 345x32mm
Thanks,
Dallin
Old Sep 19, 2012 | 09:42 PM
  #848
mikes10's Avatar
mikes10
I've got a subie with a big brake kit as well.... and rays... lol and i have bought something from ya'll in the past i just can't remember what atm - you got a great shop thanks!^^
Old Sep 20, 2012 | 01:47 AM
  #849
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
Nice picture whoring Mike. I always like seeing your cars. My buddy with a WRX orders from RSD.
Old Sep 20, 2012 | 03:40 AM
  #850
mikes10's Avatar
mikes10
lol thanks ^^
Old Sep 20, 2012 | 06:20 PM
  #851
rallysportdirect
Very nice Mike! Both cars are looking good and both have the basics covered from the looks of it and then some Keep up the nice work man!
Thanks,
Dallin
Old Oct 4, 2012 | 09:03 AM
  #852
SDGenius's Avatar
SDGenius
Old Oct 12, 2012 | 01:12 PM
  #853
taywan's Avatar
taywan
Got 1 corner on during little lunch break today. Will finish up later tonight and test ride!!!! Kinda wanted the chrome polished calipers but oh well. What do y'all think of the blues??
Old Oct 15, 2012 | 03:49 AM
  #854
taywan's Avatar
taywan
Talking
She's all finished now!! Loving it ;-)
Old Oct 15, 2012 | 03:58 AM
  #855
G35BAW's Avatar
G35BAW
Hella Dope!
Old Oct 15, 2012 | 07:01 AM
  #856
WillyP28's Avatar
WillyP28
damn those brakes look sick on your car
Old Oct 15, 2012 | 07:04 AM
  #857
taryon's Avatar
taryon
Looks amazing Taywan!
Old Oct 15, 2012 | 07:05 AM
  #858
taywan's Avatar
taywan
Thx *****!! Didn't u post smthg saying that blue was gona look hot w the DB?? G35baw said it also. Y'all called it. I'm really diggin it.!!!!
  #859
Bmurray350z's Avatar
Bmurray350z
Taywan.. good **** man
Old Oct 15, 2012 | 07:50 AM
  #860
Robert_K's Avatar
Robert_K
Didn't Go Cheap
