Clank sound from rear of car. Please read.
Old Apr 10, 2008 | 06:27 PM
username's Avatar
username
Default Clank sound from rear of car. Please read.
Well tonight I was driving and pulled into a gas station. Then entrance was a slight imbankment (sp?) and as I entered the gas station while making a left I heard this POP/Clank sound from the rear of the car.
I have all stock suspension and sway bars, but I do have after market rims but I have had those for 3+ years.
Has anyone found a solution to this problem? Any helps tips would be much appreciated.
Old Apr 10, 2008 | 06:36 PM
CSF's Avatar
CSF
what are the conditions where you can repeat the noise? does it pop/clank everytime you're on an embankment?
drivenCSZ's Avatar
drivenCSZ
you could need new endlinks for your swaybars
Old Apr 10, 2008 | 06:47 PM
username's Avatar
username
This is by far the loudest that I've ever heard.
Maybe over the last month or so, I thought I heard a clank/thud sound from the rear, but I thought that it was some items in the trunk shifting around. The times that I heard those was when I would hit this same small dip in the asphault on my exit ramp. I would maybe be going 2-3mph since that small dip was at a stop sign. So I would basically be just rolling through and then I started hearing it more and more and more.
Now tonight, I get this clank sound while going about 5-6mph. It was loud and I am almost certain, that i felt the clank sound.
Old Apr 10, 2008 | 07:38 PM
Grommit's Avatar
Grommit
Endlinks would be my guess. Do you have aftermarket sways?
Old Apr 11, 2008 | 03:41 AM
username's Avatar
username
No, everything is stock except the wheels.
What would be a good recommendation to get this to stop?
Old Apr 11, 2008 | 03:51 AM
drivenCSZ's Avatar
drivenCSZ
you could try new rear sway bar end links...im not sure if that's the issue but new OEM ones are only about $25
http://www.trademotion.com/partlocat...=25&model=350z
Old Apr 11, 2008 | 07:16 AM
username's Avatar
username
Thanks.
Old Apr 11, 2008 | 07:49 AM
username's Avatar
username
DrivenCSZ.... will those end links fit on my car? I didn't specify, but I have the G35 sedan 03.
Thanks again.
Old Apr 11, 2008 | 04:10 PM
drivenCSZ's Avatar
drivenCSZ
not sure...but everythingnissan has infiniti parts.
http://www.trademotion.com/partlocat...odel&siteid=55
Old Apr 12, 2008 | 06:48 AM
username's Avatar
username
Thanks, I went ahead and ordered the front and rear end links. Thanks again.
Old Apr 12, 2008 | 12:04 PM
SniperHunter's Avatar
SniperHunter
Also check to make sure your hatch is secured properly, slip your fingers underneath it (when it's closed) and try to see if it'll move around.
Old Apr 12, 2008 | 07:11 PM
username's Avatar
username
I don't have a hatch. I have a 4dr g35.
Old May 1, 2008 | 02:14 PM
A.H's Avatar
A.H
Does anyone know how to get rid of the clank you get after you install coilovers. The sound only comes from the rear and is neverending. Any suggestions to lessen the clanking if not completly remove it? Thx
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
