stance coilovers
Old Apr 16, 2008 | 09:48 AM
joe645733's Avatar
joe645733
Default stance coilovers
hey guys i just got my coilovers in.
and totally lost...
thegold ***** that io place on the top is for ride height? or the dampening?
pics of pointing what is what would be awsome...
Old Apr 16, 2008 | 09:51 AM
Motormouth's Avatar
Motormouth
you are holding it upside down.
Old Apr 17, 2008 | 07:52 AM
n1cK!'s Avatar
n1cK!
Infiltrator!
***** adjust dampening...perches adjust height.
Old Apr 17, 2008 | 09:07 AM
Lawy'dU's Avatar
Lawy'dU
***** adjust rebound. The rings at the bottom of the spring part of the front shocks adjust the height. Same goes pretty much for the rears. I'd recommend you have this installed by someone since you seem like an extreme newb (no offense intended)
Old Apr 17, 2008 | 10:01 AM
Gsedan35's Avatar
Gsedan35
They don't just adjust rebound, turning the **** adjusts dampning, rebound and compression at the same time. Though some coilovers claim to be DA but only adjust rebound as seen on the dyno.
Top ring closest to the springs adjust's spring preload, which should be kept at the lowest possible levels, the min amount required to keep the spring seated with no weight on the suspension. The middle ring lock's the ring above it in place. The bottom right locks the height adjustment system in place, since his coilovers are a true coilover in the rear, this is also true in the rear.
+1 on having someone else do the install.
Old Apr 17, 2008 | 10:59 AM
n1cK!'s Avatar
n1cK!
Infiltrator!
Originally Posted by Gsedan35
+1 on having someone else to the install.
+3...
Old Apr 17, 2008 | 11:14 AM
Allen331's Avatar
Allen331
^lol
Old Apr 17, 2008 | 02:51 PM
350ZYALATA's Avatar
350ZYALATA
Tentill4z
Who convinced you to try and do this yourself when you don't even know the first thing about them?
Old Apr 17, 2008 | 02:54 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
i think he gets it now...we should all stop.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Stevo Z
Oct 3, 2015 09:14 PM
