Opinions on lowering for MY 08 Z
Old Apr 24, 2008 | 12:15 AM
unpluggedk's Avatar
unpluggedk
Default Opinions on lowering for MY 08 Z
Hi, I have an 08 touring coupe Z, and I am looking forward to dropping it a little, NOT slammed
First thing is first, I don't know if anything changed from 07 to 08 in suspension.
So, after searching and reading many posts, I have decided to put up my own Q for an 08 and seek an advise.
1. I would like to avoid a use of camber kit, so, it seems like my best bet on springs are hotchkis or s-tech.
2. for shocks, I would like to keep it stock, but if I were to change it, I would prob go d-spec. (or even HP blue depending on some advises in advance )
My thoughts.
1. hotchkis spring + d-spec/HP
2. s-tech + d-spec/HP
3. hotchkis spring on OEM shocks
4. s-techs on OEM shocks.
At the moment, my Z would be my daily driver, and I do not plan to participate much in autoX/track events (at least for now )
thanks,
Jason
Old Apr 24, 2008 | 01:13 AM
GodSendsDeath's Avatar
GodSendsDeath
Well you than have answered your own question. Good luck.
Old Apr 24, 2008 | 04:19 AM
chinny's Avatar
chinny
Lmao....
Every car is aligned different. Your best bet is to install it and see what camber you end up with in the back, if your close to -2 you should be ok. Some people need a camber kit and some dont. By the time i realized i needed a camber kit for my IS250 it was too late all my tires were eaten up in the inside in about 5000 miles. I had the eibach pro on it.
Old Apr 24, 2008 | 08:55 AM
unpluggedk's Avatar
unpluggedk
How are new Cobbs spring?
they sound quite suited for 07 with stock shocks with a nice drop,
AND prob not need a rear camber
can anyone verify this?
Old May 4, 2008 | 01:43 PM
Shadrackc's Avatar
Shadrackc
Mine is down about .8" from stock, looks awesome, hotchkis sways but KW Variant2 coilovers did the trick. Great cornering, rides like a sportscar should. By the way, outside of the new red, there is absolutely no difference in the 07-08.
Old May 5, 2008 | 01:53 AM
unpluggedk's Avatar
unpluggedk
i ended up with cobb springs.
for me, it is a perfect drop and
also a great enhanced feel since i am not into too much competitive tracking at the moment.
i would infact get sway bars as my next mod when i get some $$
Old May 7, 2008 | 08:11 PM
chaparro78's Avatar
chaparro78
My thoughts.
thanks,
Jason
This system is proven to be the most effective and inexpensive way to get the lowered look you may be looking for
http://kalecoauto.com/index.php?main...products_id=11
Old May 7, 2008 | 08:54 PM
Zmazing03's Avatar
Zmazing03
This coming Saturday I am installing S-Tech + Tokico HP (blue). I will let you know how it turns out! I have SPC camber/toe kit, but we will see if I can get in spec without it first (likely, S tech is only .6/.7").
wanderingstuden
Jan 28, 2016 07:03 PM
samansharif
Sep 25, 2015 12:31 PM
