Installed Brembo BBK on front but what do I do......
I installed the 14" drilled Brembo BBK on my fronts but now what do I do for the rears? I caled Brembo and they said that they won't be making a rear to complement the fronts. I knew at the time I installed the fronts that there wasn't a rear out yet but I ws told one would be coming.
I have the non-brembo rears and its starting to bug me that the fronts look amazing and then I have these crappy rears. Should I look on e-bay for a OEM Brembo rear set and then paint them to match as I'm assuming they only came in orange, correct? Or are there other options?
yes yes I should of gone with Stop Tech..... but the shop who installed my Vortch SC only dealt with Brembo plus I'm not into looks (or so I though at the time) as I do drive the car on the track 6-8 times a year and would like to have a slight upgrade on the rears.
+1 to all above...and why do you need/want 15" rears? Just go w/ a regular rear kit from them and call it a day.
Why size wheels are you running to tuck 15" rotors w/ calipers behind them?
If anyone is out there with a set of rear OEM Brembo's I'd sure be interseted in buying them. What do shops do when they take them off a car they're upgrading to? I'm assuming they keep them as the shop I used didn't give me my old ones back.
I tried posting in the classifieds but it wouldn't allow me to.
I agree but someone somewhere out there must have a set kicking around collecting dust. With all of these upgrades to BBK someone must have a set of used rears that they'd like to get a couplke bucks for, don't you think?
Your best bet may be to try the junk yards. When I picked up my full oem brembo brakes, I called around and found several places that had them lying around waiting. However, they knew what they had and charged pretty steep prices.
They're gold OEM, it's an exact match for an Acura paint color commonly used to touch up chips.
Other issue is what happens with your EBD, Electronic Brake Distribution system - which is tied into the TCS/ABS & VDC if you have it. You don't have the prior balance F to R, all the more reason to get closer to a matched set. Right now you'll shift to even more front bias as more boost up front will have more effect than OEM brakes. If you don't have all that crap, nevermind
Find yourself a used set of these, paint them if you have to, the rotors come with new stickers generally, too. I'm a little OCD but having tracked my OEM brakes on my Base Model Z, they're weak and too prone to overheating pads and fluid (esp. the latter).
Originally Posted by Ahsmo
I think you will be hard pressed to find a set of rears alone.
Check Subie forums, too - for some reason STi drivers seem to think Brembos are not enough, either, so they swap all 4 out for something else. The rears will probably be a close match.
Buy a set of 4 and dump the fronts.
FS complete set from Track 350Z, just sold for $1500. Probably could turn around and sell the fronts for $1000, $500 is a lot for rears, but nowhere near what you might pay new.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
