Removing Front Brake Dust Shield
Old May 9, 2008 | 02:59 PM
JETPILOT's Avatar
JETPILOT
Default Removing Front Brake Dust Shield
I will be installing a set of big front brakes and I want to remove the front dust shield. I am supposed to trim it but I would rather remove it. Do I have to take the entire front knuckle off to remove the hub, or can the hub be removed with the assembly on the car. HELP PLEASE!
JET
Old May 9, 2008 | 06:41 PM
terrasmak's Avatar
Just cut it with tim snips , removing it leeds to problems with the wheel speed sensers. You can pretty much cut the whole thing off.
Old May 9, 2008 | 07:37 PM
JETPILOT's Avatar
JETPILOT
Thanks... I will take that advice. I have a Dremel with a cutoff wheel. I tried the tin snips and it turned into something you would put around a prison to prevent inmate escape.
JET
Old May 10, 2008 | 12:55 AM
JETPILOT's Avatar
JETPILOT
I used my dremel with a cutoff wheel and it worked great. Then I used the sanding drum attachment to smooth the sharp edges. It worked nicely.
JET
Old May 10, 2008 | 02:01 AM
creationv2's Avatar
creationv2
umm...been driving with mine off...no problems.
Obadabot
Jun 18, 2023 11:31 PM
07ZEKE
Aug 23, 2021 09:15 PM
sales@czp
Sep 23, 2019 03:30 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
