Will these work for my negative camber in the rear?
Old May 12, 2008 | 06:53 PM
twitch579's Avatar
twitch579
Question Will these work for my negative camber in the rear?
http://www.tirerack.com/suspension/s...20K&perfCode=A
Im about to drop even lower with sportlines and need a camber kit for the real, will these work to bring it back to spec??
Thanks!
Old May 12, 2008 | 09:11 PM
JETPILOT's Avatar
JETPILOT
What you want to use is camber arms and cocentric toe bolts to correct camber and toe. Not those.
JET
Old May 12, 2008 | 11:30 PM
xdrius's Avatar
xdrius
ZL33PR
hey twitch579...
you need rear camber arms and toe bolt...
i've got an SPC rear camber arms and toe bolts kit if you need it.
i bought it but realized that i do not need it. let me know if you are interested.
Attached Thumbnails Will these work for my negative camber in the rear?-spc.jpg
Old May 13, 2008 | 07:50 AM
Gsedan35's Avatar
Gsedan35
Thanks!
Yes, providing that Tirerack also has this Eibach kit to sell to you as well.
It's part number 5.72055k, it's pair of elongated toe cam bolts for the rear. When you dial out more negitive camber in the rear, it takes away toe, you need something that can adjust more toe then oem.
Eibach alignment parts are made by SPC btw.
Old May 13, 2008 | 12:30 PM
mzdfc3s's Avatar
mzdfc3s
why would you pay $405 for two bolts and some washers???? i wish i would have invented that!
Old May 13, 2008 | 02:12 PM
xdrius's Avatar
xdrius
ZL33PR
It's $199 for the rear arms as well as the toe bolts. =)
Old May 13, 2008 | 03:56 PM
Nukiz0r's Avatar
Nukiz0r
I might be interested.
m_0g
Jun 3, 2021 10:05 AM
emooheo
Oct 14, 2015 08:58 AM
seagrasser
Oct 11, 2015 03:27 PM
Shane86
Sep 17, 2015 05:33 PM
