Squeaking noise from suspension
Old May 23, 2008 | 03:09 PM
gsazabi's Avatar
gsazabi
Default Squeaking noise from suspension
Hey guys recently installed Zeal Function X coilovers, and the car has developed squeaking noise from driver side rear suspension. I'm not sure the squeaking was from the getgo cuz I was always drivng around my windowns rolled down. It's squeaking like there is no tomorrow except when I'm on smooth surface. What could be causing this squeaking noise? Could it be that my tires are rubbing against the fender instead?
Old May 23, 2008 | 03:19 PM
dieselmcore's Avatar
dieselmcore
hmmm maybe a camber issue... well, if u did the install urself... get it checked or sumthin at bob janes t-mart or sumthin... if u had it installed at a shop, take it up with them sorry man.. no help here... good luck...
Old May 23, 2008 | 03:44 PM
gsazabi's Avatar
gsazabi
Camber issue? What sort of camber related issue would it be? I haven't installed camber arms, but I know people who slammed their car with crazy negative camber issue and don't have this problem.
Old May 23, 2008 | 06:42 PM
350 Rookie's Avatar
350 Rookie
its not camber. Its kinda hard to diagnose over the forum since i cant hear it.
is it like one constant sqeek or like a dashed sqeek.
Old May 23, 2008 | 10:55 PM
gsazabi's Avatar
gsazabi
It squeaks constantly while the suspension is moving up and down. squeak squeak squeak squeak...
Old May 24, 2008 | 12:44 AM
formulaZ's Avatar
formulaZ
well, its just basic coilover noise from what your saying. remember you are replacing your stock rubber/plastic top mounts with a full metal pillowball mount/spherical bearing. ive heard squeaking on every coilover i have ridden in with that type of top mount, unless its rattling or something then you may have an issue.
try to set the dampening a little higher (harder) setting.
Old May 24, 2008 | 04:18 AM
azula's Avatar
azula
^+1
the noise is perfectly normal, my bc racing coils do the same thing. it scared the sh*t out of me the first time i went over a bump, it sounded like i ran over a cat.
Old May 24, 2008 | 11:35 AM
j.arnaldo's Avatar
j.arnaldo
Lube job???
Old May 24, 2008 | 11:40 AM
gsazabi's Avatar
gsazabi
Yea that's what I was told by few others as well, but it's weird it's only coming from one side, not both. I'll have it checked on Monday though.
I don't think I can afford to higher my damper settings for street use..anything higher will be only suitable for track use, lol!
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
