TEIN Flex with EDFC Review (yes another)
Old 07-17-2003, 06:39 AM
3rdpower
3rdpower's Avatar
Thumbs up TEIN Flex with EDFC Review (yes another)
Took a while But I finally got my TEIN Flex w/ EDFC installed. My overall satisfaction is an 8.5 out of 10. Great system overall. I dropped the Z until the my 19" iForge rims were tucked and then had to raise it again because I couldn't get in my dang apartment driveway!!!
Performance:
Over stock ride quality I'd definitely say there's a markable improvement through all dampening settings. The highest dampening comes close to stock, however, it just a tab bit more stiff. At the 0 dampening level the car definitely cuts into corners better. There's also a noticeable increase in road pebble noise I've hit a couple turns a bit faster then normal and the Z seems to grip better with no dampening. It sortah cuts into the turns and the tires are a bit less likely to lose grip.
Features:
Well there's no comparision in my opinion. There is no other coilover kit that's going to give you the feature/functionality for THE STREET. These are definitely not track coilovers mind you, however, you could have a little bit of fun at the track with them. The EDFC is going into the ash tray (custom job and pictures to come). It's simple to read and understand with 3 button memory.
I think once I have finished the drop it' look nice, however, be a bit on the higher side from some of the other TEIN systems I have seen. I'd like to pull it down LOW low but just can't. Overall satisfaction is high... this is a great little system and well worth it for any street drivers who are searching for a bit more suspension spunk. Please email if you have questions.
EVO sways, JUN Flywheel reviews to follow soon.
Old 07-17-2003, 09:58 AM
failsafe
....for your health
failsafe's Avatar
Any noises? Many other Tein owners (including myself) are experincing some minor rattling coming from the rear when htting bumps.
Old 07-17-2003, 11:06 AM
3rdpower
3rdpower's Avatar
I had a VERY loud noise a couple days back - I went back into the installer and he reset everything - rattle went away and no creaking there otherwise.
Old 07-22-2003, 09:18 AM
mannZ
mannZ's Avatar
Can you post pics with the setting you have now.
It would be cool to see some pics of it low and tucked but that might be too far out of your way.
Old 07-22-2003, 10:47 AM
FlyingToaster
FlyingToaster's Avatar
Hello,
Thanks for the review. I have few questions for you if you do not mind:
Are you using the standard springs that they usually come with (I think they are 560f/560r) or have you chosen a different set?
Have you specified a specific suspension frequency when ordering or just picked the "default" one?
Do you know the net springing effect the Evo bar will have on the TEIN?
Thanks.
Old 07-22-2003, 01:22 PM
2003z
2003z's Avatar
what are your wheel widths and offsets? It doesn't look like my car could be lowered without rubbing fenders.
Old 07-22-2003, 01:43 PM
failsafe
....for your health
failsafe's Avatar
2003z- I'm running 8.5" F, 9.5" R. +22 offset all around. No rubbing issues.
Old 07-22-2003, 01:47 PM
LaoSiFu
LaoSiFu's Avatar
The great thing I love about the Tein is the EDFC unit
Old 07-22-2003, 02:32 PM
2003z
2003z's Avatar
Great news! According to the offset calculator, our rear wheels stick out exactly the same to the wheelwell, and my fronts are in 5mm more than yours. Maybe I'll get the eibachs after all!
Old 09-15-2004, 04:34 PM
axxizzer
axxizzer's Avatar
why not good for the track?
me good no english spreche
Old 04-19-2005, 09:40 AM
35ounces
03 CS Track 6MT
35ounces's Avatar
Just had mine installed this last weekend also.
I think even at the highest setting it is considerably stiffer than the stock suspension and handles MUCH better. On the lowest setting the car is unbelievable. Overall a great mod and unlike what some people told me, the Tein Flex will not rattle your teeth.
Old 04-19-2005, 11:32 AM
OvaYahead
OvaYahead's Avatar
Do you think the noise is the bump stubs? I have a bobbing noise in the rear and sometimes the front. I thought it was the bump stops jumping around. I've been looking for some replacement bump stops that fit tightly around the shaft.
please excuse my vocabulary, but I don't know how else to describe it.
Old 04-19-2005, 01:27 PM
Superhung
Superhung's Avatar
I have the same noise too.... I think it can be fixed though
Old 04-19-2005, 02:32 PM
thawk408
thawk408's Avatar
I would also like to know why you think this suspension is not a good setup for the track? According to everything I have read and heard it should do more then fine on the track.
Old 04-19-2005, 04:07 PM
Mr_Q
Mr_Q's Avatar
Yeah, I mean I've taken my Z with stock tires, brakes and suspension around the track for 5 laps and smoked everyone.
Unless he means for full time racing? For weekend track warriors the EDFC setup is plenty!
Old 04-19-2005, 04:22 PM
Rickdogg
Out of hiatus
Rickdogg's Avatar
Sweet! What tracks do you go to? I would love to run against another Z
Old 04-19-2005, 06:14 PM
chaknchngo
chaknchngo's Avatar
Maybe somebody here can help me.. I would like to get Tein Type Flex. But since I work where it requires me to go up driveways and such I wanted to be able to get it as close as to stock height as possible w/ max height setting on the type flex. I do scrape @ stock height from time to time if I don't get it at the right angle. The info below is from their website..it states...
FRONT
Approx Lowering Height Adjust Range
-.87 inches Max 1.34/ Min -2.36
REAR
-.83 Max .12/ Min -1.3
Does this mean that I can go up +1.34 and down -2.36 from stock height or from the lowered height? Can anybody clear this up for me? If these numbers are correct on the fronts I should @ least be able to go up 0.47 inches higher than stock height right?
Old 04-20-2005, 11:53 AM
chaknchngo
chaknchngo's Avatar
anybody??
Old 07-20-2006, 06:59 AM
Novidem
Novidem's Avatar
Default Any body know this ?
Performance:
Features:
Hi all, i don't have much experience about suspensio but i like this solution for my new 350z 2006 .
When it come i like to change the original with this :
http://www.rtec.ch/webshop/product_i...15d29a155966c2
TEIN Super Street Damper inclusive adjustable compression and rebound, upper pillow mounts and adjustable damping force
for Nissan 350Z (QSP24-BVAS3)
What do you think about ? Every impression is appreciate a lot....
And if isn't good this, what's another ??
I USE MY CAR ONLY IN A STREET, NO RACE, NO TRUCK...THANK YOUUUU NOVIDEM
Old 07-20-2006, 07:13 AM
Jim@Showstoppers
Jim@Showstoppers's Avatar
tein is a great company with easily some of the best suspension out there. I've had Tein SS-p, Tein Flex, and even Tein S tech springs on my RSX. The Tein flex's are ovsiouly the better of the three but come with a hefty price tag. If you plan to just use your car for street use and daily driving I would suggest the Tein SS-p wth the EDFC.
Quick Reply: TEIN Flex with EDFC Review (yes another)
